F22B DOHC swap
Im putting an F22b Dohc motor in my 92 honda accord, and the dizzys not match. ive been researching and i guess the F22b dizzy is internal. is there a way to use the f22b dizzy intead of swaping them out? any help is appreciated
Are you using the F22b dohc engine harness ? If not take the Harness that plugs into the external coil pack and cut the plug off . Next loop the blue and yellow/black together.
I swapped in a newer F22 SOHC into my 93 accord. Instead of cutting the harness to remove the plug, what I did to solve this issue was just insert a fuse to close the coil circuit. It worked out great. I'm not sure if that's a common solution, but I've been running like that for 6 months now without issue.
Good luck
Good luck
DC2LURKER
Aug 2, 2014 12:10 AM
JCracer723
Dec 4, 2003 04:30 PM
