Honda S2000 Honda S2000
s2k f20c pistons
Old Nov 22, 2010 | 07:20 PM
g-gameslude18's Avatar
Default s2k f20c pistons
Where can I buy a set of used or new stock f20c pistons for my 2001 s2k?
Old Nov 23, 2010 | 05:34 AM
thundernoodle's Avatar
Default Re: s2k f20c pistons
dealer.
Old Nov 23, 2010 | 06:54 AM
Yes but they will total over $850 with rings. Forged aftermarket pistons cost less. Any other ideas?
Old Nov 23, 2010 | 11:35 AM
vietdragontekx's Avatar
if you have to replace the piston i would just go with aftermarket.
Old Nov 23, 2010 | 01:46 PM
HondaKyle's Avatar
Best bet would be The Mahle piston set that science of speed has. They are FRM compatible. You could get your block sleeved and used forged pistons.
This cylinder liner is not compatible with traditional aftermarket piston material and coatings.
Mahle Motorsports manufactures forged pistons using a proprietary skirt coating that is compatible with the FRM cylinder liner. These pistons are available in lowered compressions ideal for forced induction applications over 400 whp. Many customers have elected to lower compression with thicker head gaskets only to find that this changes the combustion efficiency. These flat top pistons keep the piston crown height in the ideal location. These forged pistons are approximately 50 grams lighter than a factory piston - weight has been reduced not only in decrease of dome volume but also through pockets in the forging.
Yes, I copied and pasted 90% of that.
http://scienceofspeed.com/products/e...Mahle/pistons/
Old Nov 23, 2010 | 02:53 PM
oldintegrao's Avatar
I have some pistons from an AP1 motor, PM if you interested. I can get pics.
Old Nov 25, 2010 | 06:47 AM
^ interested and p/m'd. I have not heard of one motor running mahle gold pistons in a frm block that made it over 30,000 miles.
SPOOLINmatt
Jan 13, 2006 06:13 AM
aznpreludeSH
Feb 20, 2005 09:38 AM
95c1v1cs1
Jul 28, 2004 09:44 AM
