Transmission & Drivetrain Gearboxes, Differentials, Clutches
4.4 final in ls trans
Old Nov 22, 2010 | 04:21 PM
93ls10.0's Avatar
Default 4.4 final in ls trans
okay have broken s4c tranny layin around and want to put the final in my ls trans question is do i need to use the b16 counter shaft or can i run the ls? They both are 15tooth but wondering of tooth pitch as if they are compatible?
edit: so und out it is a gsr tranny not b16 so the ls final doesnt fit the gsr diff can i use the ls diff in the gsr case? this is anoying.
edit: post 18
Old Nov 22, 2010 | 05:05 PM
Clerique's Avatar
Default Re: 4.4 final in ls trans
Yes, you have to use the countershaft as well.
Old Nov 22, 2010 | 05:21 PM
Ashvin21's Avatar
eventhough they have the same amount of teeths, the LS fd is slightly smaller in diameter at the base of countershaft, so yes you have to use 4.4 countershaft.
Old Nov 22, 2010 | 06:00 PM
93ls10.0's Avatar
cool got it thanks
Old Nov 23, 2010 | 09:02 AM
93ls10.0's Avatar
with having both trannies is there anysetup with a mixture of the two gear sets for a 400hp estimated car? will be tracked alot but also daily so i know the ls 5th is a must but what using the b16 3-4 in combination
Old Nov 23, 2010 | 02:57 PM
Clerique's Avatar
Buy a 3.07 1st, use the LS 1.9 2nd B16 3rd & 4th and the LS 5th.
The 1st two gears for traction, the 3rd and 4th for close mid speed acceleration and the 5th for your highway cruising.
Old Nov 24, 2010 | 01:45 PM
93ls10.0's Avatar
need info updated on first post
Old Nov 24, 2010 | 03:11 PM
Aquafina's Avatar
Yes, you can use the LS diff in the GSR case.
Old Nov 24, 2010 | 03:23 PM
Ashvin21's Avatar
make sure you shim it!
Old Nov 24, 2010 | 08:20 PM
93ls10.0's Avatar
where do i get the shims at and how much to shim. Sorry about the ignorance first time playin with a tranny.
Old Nov 25, 2010 | 03:08 AM
Ashvin21's Avatar
Honda dealership for shims!!! look it up online on how to shim a diff.
Old Nov 25, 2010 | 07:20 AM
mikesrex's Avatar
yes it will work, just use the 4.4 countershaft and ring gear.
also, you can't just pick what 1st and 2nd gears you want, as the 1-2 gears are part of the main shaft. you either run the LS/GSR 1-2 as they are the same, or you run the B16 1-2 gears.
if you want to build one of these transmissions on purpose, your best bet is to start off with a GSR transmission and just get an LS 3-4 setup. Might as well put in an LS 5th while you're at it for low highway rpms too.
Old Nov 25, 2010 | 02:16 PM
sk8phaze's Avatar
Icon6 Re: 4.4 final in ls trans
If you had a GSR tranny,and put in the Ls 3/4 gears, and the ls 5 gear, it would pretty much be a ls tranny since the gsr's 1 & 2 gears are the same.
Old Nov 25, 2010 | 06:09 PM
Aquafina's Avatar
GSR 1/2 is the same ratio as LS 1/2, but they are not the same.
Using LS 3/4 is horrible advice.
Old Nov 26, 2010 | 03:39 PM
93ls10.0's Avatar
I'm just puttin the final from the gsr in the ls tranny.
Old Nov 26, 2010 | 03:55 PM
SO.GA_SI's Avatar
[QUOTE=Aquafina;44093501]GSR 1/2 is the same ratio as LS 1/2, but they are not the same.
Have you found one set to be stronger or are you saying that they can't be mixed because of shaft size differences
Old Nov 26, 2010 | 04:10 PM
Aquafina's Avatar
GSR is dual cone synchro, LS is single.
Old Nov 28, 2010 | 04:43 PM
93ls10.0's Avatar
ok so new problem the mainshaft bearing (bell housing side) is siezed to the shaft I mean the first gear on the shaft is muli colored from the heat. Any one got any tricks to gettin it off? I broke my bearing puller tryin to take it off. Other option if it will work is i have the mainshaft out of the ls tranny i could use if everything will work smoothly. please help I am ignorant for tryin this for my first fix but if it can be save I would be very greatful.
Old Nov 28, 2010 | 04:56 PM
Aquafina's Avatar
If it is discolored, don't reuse it.
Use a different mainshaft with matching (i.e. came from the same exact trans) countershaft 1/2 gears. You will need to shim the mainshaft.
Old Nov 29, 2010 | 02:28 PM
93ls10.0's Avatar
so i need the gsr mainshaft. I already got a new bearing but yeah this sucks
Old Nov 29, 2010 | 02:47 PM
Aquafina's Avatar
GSR mainshaft and matching countershaft 1/2 gears.
Old Nov 30, 2010 | 07:17 PM
93ls10.0's Avatar
what are the 1/2 gears?
Old Dec 1, 2010 | 08:18 AM
Aquafina's Avatar
1st and 2nd.
Old Dec 1, 2010 | 12:29 PM
93ls10.0's Avatar
oh okay got it thanks. so just to be sure i use the 1-2 gears for the ls on the counter shaft and the ls main will work fine? nother question do u shim the countershaft?
Old Dec 2, 2010 | 07:59 AM
MFactory's Avatar
Are you trying to rebuild your tranny just by "remembering" how you took it apart? I certainly hope not.
Either get yourself a service manual, or pay a professional to do the job, otherwise, you're just going to end up with problems down the line.
