YAMADA 15100-P72-A01 oil pump compatibility?
Old Nov 22, 2010 | 02:45 PM
MiataRoadster's Avatar
Default YAMADA 15100-P72-A01 oil pump compatibility?
Does anyone know for sure if a Yamada 15100-P72-A01 oil pump fit an OBD0 B16A from a JDM CRX?
Thanks,
Bill
Last edited by MiataRoadster; Nov 22, 2010 at 02:51 PM. Reason: corrected spelling error
Old Nov 22, 2010 | 03:00 PM
m_shake's Avatar
Default Re: YAMADA 15100-P72-A01 oil pump compatibility?
Only issue I see is the lower timming cover not fitting right, because 15100-P72-A01 is a OBD2 pump w/ a crank position sensor mount, and the obd0/1 pumps don't have a spot for that.
Old Nov 24, 2010 | 05:40 PM
HAMOTORSPORTS's Avatar
It will fit just fine, you will need the 99-00 Si lower timing cover if you want the cover to fit correctly though.
Old Jan 31, 2012 | 01:05 AM
vtec_cpu's Avatar
Hi I am from Australia, and just wondering if i will also need the 99-00 Si Lower Timing Cover to use the 'Yamada 15100-P72-A01 oil pump' for a b18c2 (Integra VtiR/Integra GSR)?
Thanks
bcp7272
Oct 26, 2011 01:05 AM
90 ef
Apr 23, 2009 12:51 PM
95_red_dc
Aug 15, 2008 02:07 PM
pantastic
Honda Motorcycles
Dec 14, 2006 02:09 AM
96MidoriHatch
Sep 15, 2004 04:54 PM
