B18b with PR3's and stock LS ECU.
Ok so I live in California and have obdII 98 civic witch means i need to do emissions once a year. So my question is would a stock b18b with Pr3's piston's run safe with a stock OBDII LS ECU would it pass emission or would it mess something up? input/suggestions on this.
Your compression will be a lot higher than with the LS pistons, and therefore you will have trouble passing NoX emissions from higher combustion temps.. You may still be able to pass if you have a really good cat.
VtecCarHauler
Oct 2, 2010 06:28 AM
Wazup
13
Feb 17, 2008 07:21 AM
