Best intake / exhaust setup for a stock D15B1 ?
Old Nov 21, 2010 | 10:38 PM
hell_sol's Avatar
Default Best intake / exhaust setup for a stock D15B1 ?
Hi guys, i just bought a completely stock 91 hatch std and i'm not really looking to dump any money into it, so i think i'm just going to upgrade the intake and exhaust.
Since the D15B1 engine is so underpowered, i was curious what the best intake exhaust setup would be ? ( dyno proven, no guessing please ! )
As far as intake goes, i was thinking about installing a cone filter right on the throttle body. I've heard these engines actually lose torque from a long piped cold air intake setup. Is that true ?
I'm not sure what i'm going to do with the exhaust but i was wondering if you guys knew what the best cheap setup would be.
Old Nov 22, 2010 | 01:25 AM
661rex89si's Avatar
Default Re: Best intake / exhaust setup for a stock D15B1 ?
you have better luck starting with a mpfi swap and a6 cam swap which would make a bigger impact than I/H/E. after you do than look forward to a ebay header and 2.25 exhaust and 2.5 inch intake from ebay with a k/n filter then swap the IM to maybe a z6 or y8.
Old Nov 22, 2010 | 06:03 AM
SIred91's Avatar
Rainman
Intake and exhaust on your stock D15 will only make it louder.
Start with what was suggested above, or swap to a B series or a Z6/Y8
Old Nov 22, 2010 | 06:11 AM
alex14's Avatar
I just put an Intake and header (no exhaust) onto my B2 and I can say the header made a huge difference. I dont have a dyno sheet but I can say its got a lot more low end power than it did before.
Old Nov 22, 2010 | 11:10 AM
mruneek's Avatar
a header and a intake manifold (swap to mpfi) would give you a bigger gain then a "tube" intake. if you are trying to keep costs down, pick up a y8 manifold and injectors and a resister box and a a6 computer, and some headers. you are looking at about 200 bucks. then pick up 2.25 exhaust.
Old Nov 22, 2010 | 04:16 PM
hell_sol's Avatar
Very good suggestions.
So would i benefit at all from removing the huge stock airbox setup and putting a cone filter right onto the throttle body?
Old Nov 22, 2010 | 04:42 PM
661rex89si's Avatar
dude stop being a idiot and listen to what a few of us are saying.
Old Nov 22, 2010 | 07:06 PM
jdm ef8 89's Avatar
Honestly I would just leave it stock because I had a d15b2 with those mods you where talking about and it felt super slow still. The d15b motor doesn't respond much(if at all ) to mods. Like they said mpfi swap and a6 cam will make a difference tho.
Old Nov 22, 2010 | 10:03 PM
CrxChicken's Avatar
for the price of and time of installing a cam, manifold with injectors and computer you should really just put a b18 in it. NO you should really just buy a car with a B18 in it.
I tell you when I was a younger I had a mustang with a 302ci in it
I dumped tons of money into crap that only gave me a little more performance
dual exhaust, 4 barrel, headers, cam, rebuilt my trans and put a torque converter and shift kit in it... so much garbage.
I probably got 50-75hp on top of the 300hp i already had
In one weekend I could have hit the junkyard and for $400
Found a LTD or a truck with a 390 or a 428 and a C6 transmission
Bought a set of coil springs and a transmission linkage kit
I would have saved myself 80% and had a car almost no one could have beat.
Unfortunately being clueless and with no advice other then Hotrod magazine and all the garbage people who just want to sell product I didnt understand I was being taken for a ride...
Listen when people say that engine cant give you great performance and any small changes you do to it wont be significant.
Tune it up ... live with what you have and realize .. you didnt buy a race car ... its a gas saver heheh
a filter ... even a cam and manifold wont do much
still peppy though
Old Nov 24, 2010 | 03:44 PM
hell_sol's Avatar
Assumptions assumptions assumptions...
661rex89si, stop being an idiot and read my original post. I seem to remember saying... "I'm not looking to spend any large sum of money". So now i've said that twice in case you forget and feel the need to be rude about it again.
To everybody else, i appreciate the replies, but I'm not looking to build a drag car. I was just wondering what i could do to my D15B1 for cheap or free to get a little easy horsepower.
Old Nov 24, 2010 | 04:51 PM
Radim's Avatar
Do a MPFI swap first, then buy the intake and exhaust after.
MPFI should run you about 50-100$ depending on how cheap you find the parts for.
Or better yet, just get an A6 head and swap it while you do the MPFI conversion
SI Transmission will make it a lot peppier, remember the B1 only has like 70HP stock.
Old Nov 24, 2010 | 06:35 PM
661rex89si's Avatar
im not the idiot who thinks putting a cone filter on my tb will net some kind of power. everything i said is not expensive . a6 cam is like 25-35 bucks, mpfi swap is cheap as well if you have the ***** to do the wiring yourself and not send in your harness.
Old Nov 24, 2010 | 06:37 PM
661rex89si's Avatar
true but buying the a6 head is pointless since its the same head as the b1/b2/b7 head both pm3 head different cam. then again u get a spare head so yea your right.
mpfi swap and a6 cam can net you up too 110 hp its been proven.
Old Nov 24, 2010 | 07:06 PM
jdm ef8 89's Avatar
Actually youd probably feel the most difference with an Si tranny over the DX one I know I did. And my dx had a stage 2 clutch and my si had a stage 1 and the si one still felt a lot better.
Old Nov 24, 2010 | 07:51 PM
661rex89si's Avatar
only difference between the dx and si transmissions is the final gear 3.88 for dx and 4.25 for the si they both share the same gearing 1-5th but that final drive makes a difference.
Old Nov 25, 2010 | 07:06 PM
hell_sol's Avatar
I think i might do that.
Does the engine need to be pulled to drop the tranny? I don't have a cherry picker but if all it takes is pulling some CV axels and some bolts, i'm game.
Are the std CV axels and the shift linkage compatible with the Si tranny? My std is a 4 speed.
Old Nov 27, 2010 | 02:10 PM
TeamRedline89Hatch's Avatar
Yes, I have an Si motor/trans in my std hatch using std axles.
Old Dec 5, 2010 | 11:32 PM
hell_sol's Avatar
So can anyone tell me whether putting a cone filter straight onto the throttle body would be a good idea or not. Since the D15B1 is so intake deprived, i was thinking that this would be the best intake setup.
Old Dec 6, 2010 | 12:48 AM
clubworkz's Avatar
Try it and tell us, they are only about $25 at auto zone.
Old Dec 6, 2010 | 08:47 AM
lunalink's Avatar
that would be the ugliest looking ****
Old Dec 6, 2010 | 08:54 AM
speedooo's Avatar
That would be a terrible idea. The d15b1 is worthless, you wont feel a noticeable increase in power without boost.
Old Dec 6, 2010 | 08:55 AM
lunalink's Avatar
Thats dumb. I have a D15 and did an mpfi swap and i felt a difference without boost..
And its a fukn auto
Old Dec 6, 2010 | 09:38 AM
Dc4iNtEgRa's Avatar
Is Partying at your House
Engine is scrap metal. As already said, intake and exhaust will just add sound not power.
Old Dec 6, 2010 | 10:11 AM
lunalink's Avatar
SOUND is POWER
Old Dec 6, 2010 | 10:58 AM
mruneek's Avatar
putting a filter on the tb is problably pretty pointless. 1 it might not fit. the dp intake plennume sits pretty high in the bay. so u might be smushed against the hood. 2 looks GETTO. buy a short ram off ebay for the same price.
and like everyone already told you do a mpfi swap and put a header on it. the stock b2 exhaust manifold is really restricted.
