Any stock body crx or ef civics running front mount turbo's?
Old Nov 21, 2010 | 09:14 PM
1FASTHF's Avatar
Default Any stock body crx or ef civics running front mount turbo's?
Please post pictures of your front mount turbo set ups wether it be water/air or air/air.just trying to get some ideas.thanks.
Old Nov 21, 2010 | 09:22 PM
J. Mills's Avatar
Default Re: Any stock body crx or ef civics running front mount turbo's?
Mine
Old Nov 21, 2010 | 09:24 PM
CO_RaceFab's Avatar
this is my old setup from 2007-spring 2010 this was a sc6176 i have a forward facing s372 now with a a/w
ill post some of my new kit in the morning
Old Nov 21, 2010 | 09:44 PM
1FASTHF's Avatar
NICE!!! J.Mills any engine bay pics? PFI any info on turbo manifold?
Old Nov 21, 2010 | 09:51 PM
CO_RaceFab's Avatar
Its a one off pfispeed manifold. my new one is even nicer divided housing twin tial 44s.... like i said ill post pics of my new one... the hard part of foward facing manifold is the down pipe. like in an ef you dont have much room behind the bumper for the compressor housing so its tight space wise
Old Nov 21, 2010 | 10:03 PM
1FASTHF's Avatar
yeah.i had a top mount made for mine and practically had the core support cut out.i have always loved the front mount look so i think im gonna attempt it.the front mount manifolds out on the market are based on the eg/ek chassis so i doubt they will fit.
Old Nov 21, 2010 | 10:15 PM
CO_RaceFab's Avatar
Yea the of the shelf units probably wont like i said my new one is sweet super simple
Old Nov 21, 2010 | 10:23 PM
1FASTHF's Avatar
cool.any chance of fabbing up another?
Old Nov 21, 2010 | 10:58 PM
turtleman321's Avatar
afi's front facing turbo manifold fits the ef chassis pretty well. i have a friend with an ef 4 door and afi manifold and a 35r and it fits nice
Old Nov 21, 2010 | 11:03 PM
CO_RaceFab's Avatar
Im sure we could do something for you
Old Nov 21, 2010 | 11:23 PM
1FASTHF's Avatar
i'll check out the pics once posted PFI.can u get some pics turtleman?
Old Nov 21, 2010 | 11:35 PM
Mr. Em1's Avatar
i think the front mount turbo manifold is the only one that you might actually not have to mod anything/much as compared to nearly everything else on the market, unless the manifold was made specifically to fit in an ef with whatever specific turbo.
Old Nov 22, 2010 | 04:43 AM
Guñy's Avatar
the crx is a friend is your old set up
Old Nov 22, 2010 | 05:14 AM
B18c1turboedEK's Avatar
We are finishing a crx up. Ill post pics later on. I must say it has been a pain in the *** fitting everything. In a small bay.
Old Nov 22, 2010 | 10:05 AM
1FASTHF's Avatar
I've heard of people using off the shelf manifolds but have not seen one actually installed...i know what you mean B18c1.i lost count of how many times my fabricator dropped the f-bomb while doing my top mount (he never cussed prior to that).didn't help when i decided to change turbos when the manifold was 95% done either..lol looking forward to those pics!
Old Nov 22, 2010 | 10:22 AM
sanman000719's Avatar
i have a redline top mount manifold on mine at the moment with a t4/pt67 its a little tight but not to bad just had to cut into the light a little bit
Old Nov 22, 2010 | 11:48 AM
kyle3838's Avatar
Old Nov 22, 2010 | 02:27 PM
EGJDM's Avatar
Here is Wopsicle69 ef!
http://sphotos.ak.fbcdn.net/hphotos-..._1338862_n.jpg
Old Nov 22, 2010 | 02:53 PM
CO_RaceFab's Avatar
i have no light im my garage at my house these are the best i can do lol
Old Nov 22, 2010 | 06:40 PM
speeddave's Avatar
do you guys ever run into issues with sucking up debris?
Old Nov 22, 2010 | 07:38 PM
All his pictures are on Facebook so I don't think they will work
Old Nov 22, 2010 | 07:41 PM
J. Mills's Avatar
Yep, birds, bugs, small rocks, & baby's.
My car only see's the track. If im not in the staging lanes both my turbo inlet and exhaust are capped off.
Old Nov 22, 2010 | 08:14 PM
speeddave's Avatar
haha nice! baby sucker ftw
anymore pics/specs of your engine bay/setup J.mills?
Old Nov 22, 2010 | 08:42 PM
CO_RaceFab's Avatar
We run at a few hill billy tracks i have sucked up a few grasshoppers lol i watch videos of those runs and i swear i see puffs of smoke that are hoppers burnin up.... other than that i am just carefull like while im in line behind the burnout box i have someone stand in front of the car, and when its on the trailer i keep the cover on it.... on my old setup it saw some street use so i had an hks filter on it
Old Nov 22, 2010 | 08:54 PM
J. Mills's Avatar
I have no good recent pics. The following picture is from when it was still in the works. Its missing the wastegate, downpipe, and much more.
Its a simple setup.
LS/Vtec
AEBS sleeves
Stock bore
Manley Turbo Tuff Rods
CP pistons
B16 head
B16 cams (not for much longer)
Supertech Valve Springs & Retainers
Ferrea Valves
Custom intake manifold
Custom turbo manifold
Air to water
Q45 throttle body
Precision 6765 (debating a switch)
The last pull on the dyno was at 36psi making 778. It has since been turned up to 40+ psi
Over the winter i think the precision unit is going, as well as the stock cams. I also need to do something with the transmission and axles. Im still on a stock gear set and axles. I don't want to turn the power down, and every outing with the car i have been breaking both constantly.
