whats are the best replacement cam seals?
Old Nov 21, 2010 | 07:14 PM
LavishTheKid's Avatar
Default whats are the best replacement cam seals?
For a b18b1 integra dc4.
Old Nov 21, 2010 | 07:16 PM
Default Re: whats are the best replacement cam seals?
im thinking about getting the blox cam seal cap
Old Nov 21, 2010 | 07:43 PM
igorka_91's Avatar
O.E.M........hasnt failed me yet with good oll hondabond
Old Nov 21, 2010 | 08:39 PM
JdmTypeRdc2's Avatar
OEM or Skunk2 if you want a little more bling.
Old Nov 21, 2010 | 09:02 PM
el crapitan's Avatar
pocketed my skunk2 cap from the wrecker last year. still dry as a bone
Old Nov 22, 2010 | 06:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Replaced the revised version of the OEM cap (plastic with O-rings instead of just straight rubber) this year after being in service 7 years and nearly 200K miles. Can't beat that. I don't even think it was actually leaking. I only replaced it because I had a leak in that area and replaced it along with VTEC oil seals, etc.
Old Nov 22, 2010 | 07:45 AM
Spawne32's Avatar
go with the blox, or any other particular style like that with the o-rings, oil up the seals before you install it, and then reassemble. The only place you need to use permatex is right along the edge of the cam cap, no other place.
Old Nov 22, 2010 | 07:53 AM
Bond's Avatar
x2
I went with the GE seal as it was cheap and on sale, lol. Any will work.
Old Nov 22, 2010 | 08:48 AM
Jimmy's Avatar
Global Moderator
OEM Honda.
Old Nov 22, 2010 | 08:49 AM
Community Builder
Originally Posted by Jimmy
OEM Honda.
For some dumb reason Honda still sells the old-style rubber cam seal. You have to be sure to order the one from either 96-01 or 98-01. Just ask for one for a 2001 Integra and it'll be the revised version.
kroze
Nov 30, 2014 12:45 PM
jonyi27
Jan 27, 2013 07:29 AM
nonvtec92
Nov 1, 2009 01:28 PM
EJ1chevelle
Oct 24, 2007 09:40 PM
