Honda CR-V & Element 2WD & 4WD Element & CR-V
b20b in '00 CRV - Compatibility Question
Old Nov 21, 2010 | 05:07 PM
b18cEK's Avatar
Default b20b in '00 CRV - Compatibility Question
So my b20z is blown and I am wondering if I decide to replace it with a 97-98 b20b (usdm), what all will need to be changed?
What about if I replace it with a 00 jdm b20b? What all needs to be changed if anything?
Can I use the ecu and engine harness from my 2000?
Thanks for any input!
Old Nov 23, 2010 | 06:50 AM
Boosted Power's Avatar
Default Re: b20b in '00 CRV - Compatibility Question
Should be next to plug and play. Being they're all OBD2.
Old Nov 23, 2010 | 06:53 AM
b18cEK's Avatar
Thanks
are they all obd2a or obd2b?
I have been reading and heard the b20b usdm has no crank sensor?
Old Nov 23, 2010 | 07:27 AM
94EG8's Avatar
Seagull Management
Both have a CKF sensor. Its a plug and play swap, but the B20B is only 126hp, B20Zs are 147hp so you're going to notice a drop in power.
Old Nov 23, 2010 | 08:17 AM
b18cEK's Avatar
according to this post, only the usdm 99-01 has the knock sensor for the high compression.
http://www.b20vtec.com/forums/b-seri...faq-guide.html
Old Nov 23, 2010 | 02:53 PM
94EG8's Avatar
Seagull Management
You never asked about a knock sensor, just the CKF sensor. Drill and tap a hole on the back of the block and put your knock sensor in it.
Old Nov 23, 2010 | 03:11 PM
b18cEK's Avatar
Opps, sorry! I meant knock sensor, not crank.
So both are obd2b? My 2000 ecu and harness will work fine on a 96-98 usdm b20b?
Thanks for your time!
Old Nov 23, 2010 | 03:44 PM
NaveLB's Avatar
I swapped a b20b into my 2000 honda crv. I bought the motor from Hmotors and bought the high compression one. I had to buy and oem oil pump for the motor so that the cranks sensor would fit. Now Im still throwing a check engine light and everything had plugged up correctly. Supposely somewhere on the block (the JDM one), one of the sensors is just a little bit causing it to throw the check engine light. I read it on here somewhere but I cannot find it at the moment. It is a plug and play swap. I ended up swapping the the OEM intake manifold one onto the JDM motor because I was on a budget. You dont have to do this but like I said for me it was cheaper to just do it this way. Another reason why I swapped the manifolds is because this is my daily driver and a needed it done asap
Old Nov 23, 2010 | 06:40 PM
94EG8's Avatar
Seagull Management
I believe the '97 - '98 is OBD2A, it really doesn't make much difference though. Keep your old harness, distributor and ECU.
Old Nov 23, 2010 | 07:19 PM
b18cEK's Avatar
Thanks
Old Nov 25, 2010 | 02:09 PM
You should be fine. Plus you'll have every single part you would need incase anything does go wrong.
Just don't toss the B20Z out right away and you should be fine.
Old Dec 4, 2010 | 05:10 PM
Spudenater's Avatar
If I'm not mistaken, the compression ration for pre '98 B20Bs is lower than that of post '98. 8.8 for JDM and 9.2 for USDM I believe, as opposed to 9.6 JDM/USDM.
Old Dec 14, 2010 | 06:29 PM
supra-n-civic's Avatar
the only difference between a and b are the ecu plugs nothing changes other than that so if you are keeping your ecu then dont worry about it
Old May 15, 2011 | 06:42 AM
climberjevans's Avatar
So, what is the outcome from the two people I noticed that swapped B20B's into their B20Z Cr-V? I have a 99 CR-V with a lot of miles and a local guy is selling a B20B with 166,000 miles for a good deal. Would you recommend the swap?
Thanks!
Jeff
SOHCD16y8
Dec 27, 2008 08:19 PM
HELLAnorcal
Jul 19, 2007 03:46 PM
S2k Hybrid
26
Feb 12, 2007 08:42 PM
KustomCrx
Sep 27, 2004 09:27 PM
d0nkeyxPunch
Mar 15, 2003 11:15 PM
