changing a lower control arm bushing. need help
Old Nov 21, 2010 | 12:20 PM
EF9Infantry's Avatar
Default changing a lower control arm bushing. need help
Anyone had problems changing one of these. I've lubed it and jammed the sh*t out of it and it still won't come out. Anyone have advice how else to get this bushing out.
Old Nov 21, 2010 | 12:45 PM
Clipsed's Avatar
Default Re: changing a lower control arm bushing. need help
you need a shop press to do it, good luck trying with a BFH.
Old Nov 21, 2010 | 12:54 PM
efjones9's Avatar
propane torch and have fun lol jk
Old Nov 21, 2010 | 12:59 PM
fredrocs's Avatar
i've used a BFH to knock them out and back in, but it's always been done on a lift. in this case any kind of lube is your enemy. if you're just tryna knock it out, i hope you're hitting it from the inside out and when you're installing them go from the outside in. what you really need is a tool like this http://www.denlorstools.com/home/dt1...ol_sp_651.html
hope this helps!
Old Nov 21, 2010 | 01:51 PM
Thanks guys. Damn I thought I could just knock it out with a hammer. Wish I would have checked here before destroying it then asking how to do it. Lol oh well lessons learned.
Old Nov 21, 2010 | 03:29 PM
Tyson's Avatar
yeah a press is needed to do it properly.
heating it and cutting it out is going to ruin the control arm. it will certainly burn off the surrounding paint and then require a repaint.
a balljoint press like the ones you can rent is hardly adequate enough either.
just use a proper press.
Old Nov 21, 2010 | 08:40 PM
hatchet_honda's Avatar
rear lower control arm bushing? ive always just replaced both the arms with aftermarket ones that came with new urethane bushings already. PITA to replace on stock arms
Old Nov 21, 2010 | 09:33 PM
fredrocs's Avatar
ok backing up, are you trying to replace the front lower control arm bushings or the rear trailing arm bushings? the procedure is totally different for both.
mikej94civex
Dec 31, 2009 01:39 PM
ef_zcvtec
10
Mar 20, 2007 06:45 PM
jdmunzip
Sep 5, 2006 03:51 PM
agapeBB6
Honda S2000
Aug 4, 2005 11:58 AM
MattD@Stoptech
Apr 7, 2004 07:09 AM
