bearing sleeve
Sometimes you can heat it up with a torch (propane torch will do here) and hammer a flat screwdriver in behind and pry. Or you can use a 4 1/2" angle grinder and cut a side out and it'll come off (be careful not to go too deep)
Is this the rear hub....
"Just found this answer:
https://honda-tech.com/forums/honda-accord-1990-2002-2/2000-accord-rear-hub-2290432/
Dang "
Dang "
eg:R
10
Oct 15, 2011 02:15 PM
