Help!!! My Car Wont Go Into Gear!
Old Nov 18, 2010 | 08:26 PM
dunked dc's Avatar
Default Help!!! My Car Wont Go Into Gear!
Ok so i shredded my old throw out bearing and replaced it. its b16a tranny. the bearing came out in 3 pieces and in pretty rough shape, but the pressure plate is still good, so i replace rebuild and when i go to take off....the car still wont go in gear..I then Blead the clutch and still no resaults. Any ideas? im stumped
Old Nov 19, 2010 | 12:02 AM
dunked dc's Avatar
Default Re: Help!!! My Car Wont Go Into Gear!
could the fork be bent?
Old Nov 19, 2010 | 02:57 AM
Robinjo's Avatar
did you change the clutch while you were in there? Sounds like the helper springs on the clutch aren't doing what they are suppose to.
Old Nov 19, 2010 | 04:52 AM
fv8s's Avatar
I am not trying to be mean about it, but it seems like you are somewhat inexperienced. Did you place the throwout bearing on the fork the correct way (two slits facing out), and did you make sure the forks springs sat into the ball on the housing of the transmission? Try sitting inside the car while a friend sits outside looking under the hood and make sure the slave cylinder pushes fork in and out. I have a feeling the bleeding/ installing job was done incorrect.
On a side note: Does the trans goes into all gears with the car off correct?
Old Nov 19, 2010 | 08:09 AM
dunked dc's Avatar
in not very inexperianced i built the car just over 300 to the wheels now, i did everything correctly the thro out is in correctly and i had my old man help me bleed it and yes the piston moves the fork. And correct the car goes into every gear when it is off. I did not check the clutch when i was in there its an act stage 2 and pretty new..
Old Nov 19, 2010 | 08:10 AM
dunked dc's Avatar
actually i do not know how old the clutch is it came with the motor but it is act stage 2
Old Nov 19, 2010 | 08:30 AM
WAngel's Avatar
will it go into reverse and does it scrape when it does? cuz if it does u probably have to change tha bushing under tha pedal...or jus simply a new clutch
Old Nov 19, 2010 | 08:36 AM
fv8s's Avatar
your clutch is obviously not engaging. take the transmission off and start over
Old Nov 19, 2010 | 08:58 AM
dunked dc's Avatar
will not go into reverse or any other gear if i pull hard it will slip into reverse a little and just grind...So this is a cluth problem? i did have a clutch grind b4 at high rpm fast shifting.
Old Nov 19, 2010 | 09:22 AM
fv8s's Avatar
The clutch doesn't grind man, the gears do. Take the damn trans off and start over you did something wrong. In the mean time order a new clutch
Old Nov 19, 2010 | 09:59 AM
dunked dc's Avatar
alright thanks for the pointers prolly gonna order a new clutch and fork and hopefully ittle cure the problem. thank you
Old Nov 19, 2010 | 10:16 AM
fv8s's Avatar
yepp anytime. I may have another fork. I can give it to you if I do have one. Let me check first
Old Nov 19, 2010 | 10:29 AM
dunked dc's Avatar
sweet man lmk its 2000 civic si tranny b16a
Old Nov 19, 2010 | 10:39 AM
fv8s's Avatar
k. all hydro B series forks are the same mang. mine would be from a Teg LS
ek9ina
20
Dec 22, 2013 11:46 AM
levaughnt
Honda Civic (2006 - 2015)
Jul 29, 2011 06:49 AM
G-Robinson
Transmission & Drivetrain
Apr 26, 2009 07:52 AM
Shina
Apr 26, 2008 08:19 AM
The Destroyer
18
Feb 24, 2006 06:26 PM
