Wheel Cylinder removal
Old Nov 18, 2010 | 07:49 PM
Gotrek's Avatar
Default Wheel Cylinder removal
I can't believe it's as complicated as it looks.
Can I remove my rear wheel cylinder without taking the backing plate/hub off?
One of the bolts is sandwiched between the backing plate and hub. that can't be normal.
Reason: I need to bleed my brakes but while attempting this I noticed that bleed screw is sheared off. I'm open to other options. I thought about drilling the bleed screw out but I'm not sure There is enough room.
Old Nov 18, 2010 | 08:11 PM
FSRslug's Avatar
Default Re: Wheel Cylinder removal
I dont think you need to take the plate off. Its been awhile, but I remember taking the drum off, and being able to get at the nuts holding the wheel cylinder on without removing anything else. Replacing the shoes was more difficult that replacing the wheel cylinders.
Old Nov 18, 2010 | 08:16 PM
Ludster's Avatar
I just did this the other day. One of the screws can be removed easily. The other I just used a 10mm wrench and loosened the bolt little by little. At the same time, pulling at the wheel cylinder.
Once the cylinder is removed, the 10mm bolt stayed and I just put the new on and tightened the sandwiched one all the way first.
Hope that helps
Old Nov 19, 2010 | 07:07 AM
jlicrx's Avatar
the rear wheel cylinder has only one bolt holding it on
Old Nov 19, 2010 | 09:23 AM
macef9's Avatar
Old Nov 19, 2010 | 10:10 AM
Gotrek's Avatar
Hope that helps
Genious! that's the solution thank you!
Mines rusty as sin so probably be impossible but at least there is a possible solution, and bonus if I snap the bolt heads it will come right out Then I can be like the guy above and have only one bolt
Old Nov 19, 2010 | 03:55 PM
Nooch's Avatar
i've never seen a wheel cylinder with 2 bolts haha.
Old Nov 19, 2010 | 04:41 PM
Ludster's Avatar
Weird.. All civics I have ever worked on have a 2 bolt rear wheel cylinder. You're thinking about the drum bleeding cylinder right?
After tightening one of the 10mm the cylinder still had some play in it.. It would be pretty sketchy to run one bolt in that think since it's main part that allows the rear drums to actually function.
Swansen
Sep 17, 2016 08:53 AM
jdmjunkieXL
Nov 25, 2008 01:35 PM
Milano97
Oct 27, 2006 10:28 PM
Seatown
28
Oct 13, 2006 11:00 AM
TheSSG
Jun 5, 2004 11:52 PM
