H&R oe springs..do i need a camber kit
Hi,
I just picked up a 96 gsr with H&R oe springs (.75-1 inch drop). Do I need a camber kit?
I dont want to wear out the brand new kumho 712's
I have the same springs and it's not low enough to cause major premature wear on tires. I have never had a problem with my tires even though the camber is off on the front.
no, don't waste the money, your drop isnt significant enough. My car is lowered 2-2.25" and there is no inner tire wear. My camber is fine.
whenever you lower a car the camber and toe changes.....if the toe is bad, it will also wear your tires depending on if the toe is in or out....camber kits correct the camber but not the toe
Hi,
