is honda cooling system WRONG?
Old Nov 18, 2010 | 05:04 PM
gsxrbwest's Avatar
Default is honda cooling system WRONG?
I have a 88 crx with a JDM b16. Purchased with blown head. Fixed and installed dual core aluminum radiator and dual high performance fans. The cooling system will cool all the way down to 160f. with the fans on,. If I put a thermostate in the temp rans up and up 200-->210-->220f. . this is when I cut the motor off. I have 3 branew thermostates all open at 170f. . I have removed and installed all 3 thermostates and all have the same result. I am now running my belovid b16 with no thermostate. I want the motor to run between 180f. and 200f. . Please help me any ideas will help?
Old Nov 18, 2010 | 05:06 PM
gsxrbwest's Avatar
Default Re: is honda cooling system WRONG?
In theary the hot coolant exiting the motor will open thermostat but the b16 design , the cold coolant from the radiator opens it???? ...??????
Old Nov 18, 2010 | 05:13 PM
gsxrbwest's Avatar
help.....
Old Nov 18, 2010 | 05:23 PM
Deetz's Avatar
Crazy Honda Guy
stop double posting!
Old Nov 18, 2010 | 05:39 PM
black0hatch's Avatar
i highly doubt the cooling system is wrong. alot of time goes into designing and building a car. its kinda hard to understand what your talking about. your saying the fans cool it down but then it gets too hot? maybe your fan switch isnt working?
Old Nov 18, 2010 | 09:21 PM
rwdsohcef's Avatar
likely water pump or you are not getting all the air out of the water system.
2nd guess
Its tuned/running/exhaust clogged so bad it is causeing heat.
Are you parked on a wicked down sloap?
Thats my 2 cents without more info
Old Nov 22, 2010 | 06:24 PM
gsxrbwest's Avatar
PROBLEM FIXED THANK ALL OF YOU.
I drilled 3 little holes in thermostat, Motor runs **** and temp is 180-200 f.
I belive this helped b/c it alows small amount of flow allowing hot coolant comeing out of the motor to travel through radiator to thermostat "faster?"
Old Nov 23, 2010 | 01:24 AM
Crx dude's Avatar
You could be running lean which causes the motor to get hot.
gsxrbwest
19
Nov 19, 2010 06:07 PM
ITRiWISH
18
Jul 20, 2009 06:44 PM
rktechteg
Dec 29, 2008 05:17 AM
RTW DC2R
Apr 12, 2007 05:24 PM
spaceman
12
Sep 24, 2003 06:29 PM
