How Do You Put Lower Timing Cover On
I Cant Get It BAck On The Original One Was Broken Due To It Not Being Put On Right. SO I Got A New One I Cant Get It On On Now Can Anyone tell me how it goes back on fron under the car or on top,...thnx
What I did was remove the bolts of AC compressor, pushed the compressor to the front, freed up more space. Positioned lower cover top to the front of the car, try to insert the cover by doing a sort of 90 degree clockwise movement. In the process, at some point, you may need to push cover upward a little bit. Try and error.
Goes in from below. Easier if the drive side motor mount is removed and the engine allowed to sag down (like when changing the timing belt).
x2 from under the car, having the drivers side wheel removed helps as well. The crank pulley also has to be removed if you haven't already done so.
JigsN Joints
Sep 23, 2011 01:30 AM
mem94043
May 16, 2011 12:28 PM
