Honda S2000 Honda S2000
engine fluid spec for the S2000
Old Nov 17, 2010 | 06:28 PM
phonedrn8's Avatar
Default engine fluid spec for the S2000
Here is crazy question, what are the fluid levels for the car.
engine oil
engine coolent
brake fluid
clutch fluid
trans fluid
rear end fluid
windshield fluid
what else am I missing????
Old Nov 17, 2010 | 06:59 PM
HRPfg2's Avatar
Default Re: engine fluid spec for the S2000
level? how much to top it off?
Old Nov 17, 2010 | 07:33 PM
Animosity's Avatar
I'm Hungover
missing headlight fluid
Old Nov 18, 2010 | 04:57 AM
camoy's Avatar
engine oil
engine coolent
brake fluid
clutch fluid
trans fluid
rear end fluid
windshield fluid
I believe he is looking for amounts of the fluids, poor wording.
Engine, with filter..........5.1 quarts [1]
Cooling System, Initial Fill..........8.1 quarts
Manual Transmission, SCYM (6-SPD)..........3.2 pints
Differential, Rear..........1.5 pints
As for the brake and clutch those don't have a specified amount just buy a can of super blue and you will have enough to completely flush out both. Words of advice, if you do flush out the brake I recommend you swap out new brake pads all around. If you are on worn pads and do the flush and fill, you could forget later when you go to install new pads and force the piston back into the caliper, thus causing the extra fluid to come out of the reservoir. Also be careful with the clutch flush/bleed it is easy to suck air into the slave cylinder and not know it. Things will be ok initially until the air bubble migrates, then your clutch pedal will feel squishy and your clutch won't fully des-engage. The S uses DOT 3
Windshield washer fluid amount...........................................R eally? Just get a gallon and fill it up till it is full.
globy123
Sep 27, 2009 05:32 PM
bopbop93030
May 9, 2008 07:01 PM
2k1 SSM GSR
Mar 23, 2005 10:02 AM
SilverDc2
Jun 6, 2004 08:54 PM
CPR
Feb 6, 2003 07:13 PM
