Integra GSR seats in a CRV
Hey guys so i installed GSR black leather fronts into my 98 CRV.
Here's some pictures. I love them! My old ones were worn on the outer corner twisting my back as if i was doing a hard right turn.
Passenger under seat compartment kept
just the rails would be low, here it is GSR seat with crv riser/rail (i dont know what to call it)
you will only need 10mm, 12mm and 14mm
the round ***** to adjust the butt cushion have a "c clip" like clip that holds them in, then they pull right out.. the rest is pretty obvious.
here's the view of the passenger GSR seat
here's the view of the passenger CRV seat
thanks for sharing the pics!!
now im kinda wondering if i could adopt the "risers" from our oem
seats to an aftermarket seat rails!?? when i installed/test fit a
buddy club seats and rails.. its too low, i know for sure then that
oem civic/teggy seats would be a direct bolt on its just the height
will have an issue....
something along these lines are on my "to do list" for next summer. i figured it would be as easy as a simple seat pan swap...my thoughts are confirmed! thanks
actually i did bolt up my other gsr seats on my V, its just its really low then
and im not in a mood to swap the rails, i just wanted to find out then if the
rails would bolt up! but im kinda leaning into installing my gsr cloths if ever
i will use it on my V.. other than the RSX-cloth ones w/c im still looking...LOL!
s2000 seats in my crv. they sit really low but after you get use to them they feel perfect height. the armrest and shifter are so much better. i roughly measured im sitting 4 " lower
i've often wondered about that. driving around the stock seat feels ok.. but the shifter, armrests and cupholders just seem awkward. maybe 2" lower would be the sweet spot?
+1 i've also looked into the similar bride seats. but i just can't justify spending that much on seats.
