clutch peddle sqweeks(spelling) please help
Old Sep 21, 2002 | 09:09 PM
01-0720's Avatar
Default clutch peddle sqweeks(spelling) please help
every time i press the clutch peddle it sqweeks , how do i fix this please help its very annoying
Old Sep 21, 2002 | 09:19 PM
TypeR 599's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (01-0720)
squeaks
i duno, but mine does it too...
Old Sep 21, 2002 | 09:20 PM
01-0720's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (TypeR 599)
squeaks there it is i couldnt remeber how to spell that for the world , anyway does anybody what this is an how to fix it, or should i just take it to acura my car only has 26k on it thel cover it right
Old Sep 21, 2002 | 09:28 PM
Ferrell's Avatar
my kaa does this as well....seems to be normal.
Old Sep 21, 2002 | 09:38 PM
Bbasso's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (Ferrell)
when mine sqweeked the clutch went shortly after
Old Sep 21, 2002 | 09:44 PM
01-0720's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (Bbasso)
do you think acura will fix the squeek , an my clutch hasnt been feelin to hot lately you think they will replace that to
SoCal ITR's Avatar
Mine squeaks too.
Old Sep 21, 2002 | 09:45 PM
TypeR 599's Avatar
....uh-oh...
Old Sep 21, 2002 | 09:47 PM
Bbasso's Avatar
If your freindly with the service wrighter(sp?) maybe they will hook you up. can't hurt to ask- be nice and smile alot
Old Sep 21, 2002 | 09:48 PM
Bbasso's Avatar
I just avioded whole thing and did it myself- no need for them to bitch and viod my warrenty.
Old Sep 21, 2002 | 09:50 PM
01-0720's Avatar
thanks for the info , im goin first thing monday morning
to drop off an get it fixed
thanks
eric
Old Sep 21, 2002 | 09:56 PM
SurferX's Avatar
The dealer will fix it under warranty. The service rep told me they had to drop the tranny to get to the problem so I asked about installing a Comptech flywheel while they had the tranny off. He said sure all I had to pay for was the part, labor free of charge since the tranny was off due to warranty. Free flywheel install yay! Too bad I was too poor to get a clutch upgrade at the time too.
Old Sep 21, 2002 | 10:14 PM
Rory Breaker's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (SurferX)
If youre under warranty they definitely should take care of it!
First thing would be to check the pedal and lubricate all the moving parts. Get under the dash and start sprayin like a madman
Next, pull back the boot on the slave cylinder on the front of the tranny, and lube that up real well. If you cant get in there, take a knife and poke a small hole in the rubber and stick the straw tip (if you have one) on a WD40 type spray and lube that SOB up. It should then go away...
Old Sep 22, 2002 | 06:40 AM
BudMan's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (newgsrdriver)
[QUOTE]First thing would be to check the pedal and lubricate all the moving parts. Get under the dash and start sprayin like a madman
Next, pull back the boot on the slave cylinder on the front of the tranny, and lube that up real well. QUOTE]
Here's the info of the day!! Definately try above...
***NOTE: the rubbe boot covering part of the slave cylinder pulls out & can easily be put back in ($5 says it's COMPLETELY dry!)-- just pull it out of the tranny, then recoat your slave cylinder ball joint connection with high-temp grease. You're squeaking will most likely be gone. You shouldn't need to drop the tranny for this one.
Old Sep 22, 2002 | 09:12 AM
01-0720's Avatar
Default Re: clutch peddle sqweeks(spelling) please help (BudMan)
thanks for the info
Old Sep 22, 2002 | 09:15 AM
AoiGSR's Avatar
25 Year Member
i had mine fixed under warranty. turns out the throwout bearing went dry. They then replaced other stuff as well.
total cost ot me: $0
cost to them with parts if i waited out of warranty : $600+
-A, who is glad he did it
Reebok4146
Honda Civic (2001 - 2005)
Aug 6, 2009 01:19 PM
Brett
Feb 12, 2003 04:26 PM
R-1303
Feb 20, 2002 12:05 AM
CPR
Nov 15, 2001 06:40 AM
Silude93
Oct 30, 2001 03:30 AM
