91 Honda civic si
If you build it from the bottom up you know what you have and can build it the way you want it. Could go either way I guess. Check hmotorsonline.com. They have pretty good deals on full conversions.
ok thanks. i just want to get the most bang for my buck and i dont know which route to go. b16 is the most common swap but is there anything else for less that will give me just as good of results?
I have been checking on the options myself and for the money the B16a2 seems to be the best option. Reason I say this is because you could pay around $3000 for 10 or so more HP or pay less for pretty much the same motor you have now. I would say get into a B16 and you should be good even if you want to boost eventually. It is a good motor. That is why I will be going that rout when I have the money for it.
