White smoke from exhaust
Old Nov 17, 2010 | 02:59 PM
2kdrift's Avatar
Default White smoke from exhaust
hello i am getting white smoke out my exhaust but it dosent happen all the time.
will not smoke while idling
will not smoke on WOT
if i am cruising/ not pressing gas for example going down hill for ahwile when i punch the gas a big poof of white smoke comes out the exhaust. also sometimes in the morning i get smoke on startup.
at this point im not even sure if its water being burned or oil. and i just changed teh head gasket so thats not the problem.
Old Nov 17, 2010 | 03:03 PM
Former User's Avatar
Default Re: white smoke from exaust
White smoke = coolant
Blue smoke = oil
Old Nov 17, 2010 | 03:08 PM
HatchB16's Avatar
Blue smoke = oil
what he said
Old Nov 17, 2010 | 03:14 PM
2kdrift's Avatar
Originally Posted by HatchB16
what he said
yes i have heard that before. just i dont know what considered blue but its not dark at all so i guess its just regular white smoke. is there a possibility its actually fuel?
i am running a basemap from another motor so i am guessing its running rich
if not that i am guessing its my IM gasket thats the only thing that could leak water. i have on of those heat absorption ones and it may be failing.
Old Nov 17, 2010 | 03:17 PM
BigBlock22's Avatar
Default Re: White smoke from exhaust
rich mixture or burning fuel would be black smoke
Old Nov 17, 2010 | 03:23 PM
2kdrift's Avatar
ok thanks taht helps most likely water then
Old Nov 17, 2010 | 05:14 PM
wtf69's Avatar
Most cars that old will have white smoke when they start up
Old Nov 17, 2010 | 05:18 PM
Outlaw-Hondaz's Avatar
what does it mean when waters drips out of the tip of the muffler?
Old Nov 17, 2010 | 05:30 PM
BigBlock22's Avatar
thats normal condensation from after start up or from living in a cold climate.... notice it will go away after the car has been on for a while.
Old Nov 17, 2010 | 05:56 PM
gracis!
Old Nov 17, 2010 | 06:25 PM
2kdrift's Avatar
thread jackeerrr ^^^ LOL nah but if it continue to drip water after warmup it can be more serious.my car was doing that before i swapped the head gasket
@wtf its not normal i gett big puffs of smoke and seems very intermitent
Old Nov 17, 2010 | 06:44 PM
Solster's Avatar
best way to put it is if it looks like a cloud pouring out the tail pipe it's water/coolant
if it turns blue at all it's oil.
Old Nov 17, 2010 | 08:18 PM
BigBlock22's Avatar
camdizawg, if you havent done this already....have someone smell the exhaust when you give the engine some throttle, it will have a sweet odor to it if its burning coolant. excessive white smoke is an indication of water/coolant getting into the combustion chamber. drive the car for twenty minutes and see if the problem still persist. after the exhaust system gets hot enough it should burn off any if not all water vapors that would be from moisturization
Old Nov 17, 2010 | 10:06 PM
torqen2k1's Avatar
Are you losing coolant at all? What type of oil weight and syn or con. oil using? Possibly is your throttle body leaking?
Old Nov 17, 2010 | 11:01 PM
Unphzd's Avatar
hmm im kinda interested in this too cuz my car blows faint white smoke? but i am not loosing coolant..is it just running rich?or what?
my friend said that its just running rich cuz you can smell the gas and its not a coolant leak
soo yeah id check the smell
Old Feb 26, 2017 | 05:58 AM
jeffro2017's Avatar
Hi, I just bought this 1995 honda accord 2.2 the guy said it burnt little oil, 1 qt per 100 miles when started and drove to my house like 45 min drive had no smoke coming out. I got it home changed the plugs to NKG iridium, and found no air filter installed so installed air filter. Now when i start it it smokes really bad like i am running sea foam thru it. If it sits and idle its not that bad, but if i hold the gas to 3000 rpm it will smoke you out!!! I dont understand that changing plugs and putting an air filter in would cause this. I also changed the valve cover gasket and plug seals . Anyone have any ideas? its not coolant as it is not sweet smell, and it dont smell like burnt oil its like very rich mixture smell but the smoke is whiteish in color. I was hoping someone ran accross this. I am planning putting old plugs back in and taking air filter back out and start it see if it is still smoking .
Thanks ahead of time
Jeffro
EFlovin'
15
Aug 5, 2013 11:16 AM
Redprelude98
Nov 25, 2008 10:42 AM
boostedjdmdc2
Oct 22, 2006 08:16 PM
BigIslandBoi
Nov 3, 2003 10:08 PM
R-1303
Nov 26, 2002 01:41 AM
