what to use on ls/vtec..
Old Nov 17, 2010 | 01:03 PM
shinnox's Avatar
Default what to use on ls/vtec..
i have a blown b16a and i want to make my b18a1 ls/vtec..
can i use my b16a cranck shaft with my b18a1?
planning to buy p73 pistons..
my b16a head is ported with stock cams..
is it any modification require for the block or the head to be tap?
help me please..
Old Nov 17, 2010 | 01:10 PM
all-mtr-teg's Avatar
Default Re: what to use on ls/vtec..
Let this be your guide, in the future, search the "FAQ" at the top of the forum threads list
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Nov 17, 2010 | 07:49 PM
TheCrimsonGhost666's Avatar
You can use the b16 crank . . . but good luck running the car lol according to the compression calculator with that setup you would have 5.51:1 compression, thats not enough to start the car. The thing that makes ls/vtec appealing is the 89mm stroke of the crank compared to a gsr's 87.2mm, or a b16's 77.4mm stroke. The b16 deck height is shorter than a b18 because the stroke is smaller and so are the rods, so by using a b16 crank and rods in a ls or gsr block, the pistons wont come up enough in the cylinders to compress anything. With a ls crank you use ls rods and a b16 crank you use b16 rods. With the ls crank, and everything else the same in your setup you will have 11.66:1, much more streetable lol I would suggest getting the p30 pistons btw cause they go right onto the ls rods with no machining, with the p73pistons you have to shave part of the rod, and I think the wrist pin sits higher in the p73's making less compression than the p30's or if you want less compression use the pr3's, they also dont require machining, just some food for thought.
https://honda-tech.com/forums/showthread.php?t=1676914
Heres a link to a good source for detailed info on how to build an ls/vtec and some basic fundamentals, probably the most useful thread on Honda-Tech I have ever read.
Old Nov 18, 2010 | 07:04 PM
fv8s's Avatar
why in the world would you consider putting a b16 crank in an LS? you do realize that the B16 stroke is smaller than an LS I hope.
Old Nov 18, 2010 | 07:05 PM
fv8s's Avatar
De- stroking an LS... I would love to see this in action
jksmith
Nov 3, 2008 11:14 AM
truckhigh
Jun 13, 2005 07:50 AM
JDMlyfestyle
Sep 27, 2004 02:06 AM
GumballNA
Aug 5, 2004 02:49 PM
b16vtecsol
Jan 17, 2004 07:23 PM
