Car died in mcdons drive through
ok so ive searched for this and nothing seemed useful. i was going through the mcdons drive through and of course me not giving it enough gas i kill it went to go to start it up and nothing so i got it towed home and first thing i checked was the fuel pump i loosend the fuel pump nut and its got preasure then i checked the plugs they were dry then sprayed some ether in it and it sorta started up. then died im using dsm 450 inj. each inj. reads 2.5 ohms. checked the main relay its good too so basicly im thinking power is not getting to the inj. n any comments will be apreciated
i would check the resistor box itself, make sure its grounded correctly and make sure its getting 12v. since the injectors are grounded to the ECU, you should check for power going to the resistor box and from the resistor box out to the injectors. btw, whens the last time you replaced the fuel filter?
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
JDM Freakk
Jun 21, 2011 05:36 PM
91' LS-VTEC
15
Jun 7, 2009 01:51 PM
alscrx
Mar 5, 2009 03:07 PM
white90crxhf
12
Aug 17, 2006 09:16 PM
