2005 RSX Type-S power loss and higher fuel consumption
The title says it all but I’ll try to summarize what happened and what I’ve already tried to solve this issue.
A few weeks ago, the cat heat shield metal sheet came off (rust near the screws) and cut the pre-cat O2 sensor wires and damaged the post-cat O2 sensor wires. Before this, the car was running just fine.
I spare you all the details but I ended up replacing both O2 sensors, the spark plugs and the IAT (all original parts).I replaced the IAT because I went to the dealer and they had a P0113 code and suggested to me I replace it.
I’m at a loss. I’ve spent a lot of time on this (and $$) and the car is not going any better. Help please.
Problem solved!
Problem was the ECU reset after replacement of the sensors. A mechanic pointed me to the wrong fuse (7.5A labelled "back-up") while the right one is the 20A labelled "ENG".
Car is now working great like it used to.
Bango_Vang01
Jul 11, 2012 05:40 PM
typesnick
Feb 4, 2008 09:28 AM
