EJ9/D14a4 - What is the correct fuel injector connector firing order?
Old Nov 17, 2010 | 02:22 AM
jamesyboyy's Avatar
Default EJ9/D14a4 - What is the correct fuel injector connector firing order?
hi all my cars an ej9 (D14a4)
ive put a JDM D15b inlet manifold on it but having problems.
i put the TB off my d14 IM onto the d15b IM
used IAT as TA
used my D14 injectors
using my RACV of D14 (attatched to TB) however the D15b is still in the IM... Should i remover and blank it off?
so...
the car will rev up too rev limiter but only by slowly applying throttle you cant full throttle it otherwise it will "bog out"
not too sure wether or not i have injectors the right way as this could be a problemm right?...
on cylinder one i have brown & yellow wires
on cylinder two i have red & yellow wires
on cylinder four i have yellow & yellow wires
on cylinder three i have blue & yellow wires
i have researched and had no luck theres not a lot of info out there on D14's
thanks for help much appreciated
Old Nov 17, 2010 | 04:41 AM
Former User's Avatar
Default Re: EJ9/D14a4 - What is the correct fuel injector connector firing order?
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
97civkid
Sep 1, 2012 05:38 AM
b18 type r
Nov 24, 2010 10:56 AM
Jhonny Ricer
Jul 31, 2007 11:41 PM
Ron454321
Jul 25, 2007 07:56 AM
Brooklyn101
Oct 30, 2006 11:55 AM
