93 Del Sol S: Will 91 Civic master cylinder work with 94+ Integra non-abs booster?
Old Nov 16, 2010 | 09:46 PM
zombieD's Avatar
Icon2 93 Del Sol S: Will 91 Civic master cylinder work with 94+ Integra non-abs booster?
The car 93 del Sol S, with rear disk conversion.
I have a 93 del Sol and i have already done a rear disk conversion with apropriate proportioning valve and i love it. Problem is i noticed a leak at my master cylinder and ive always wanted to get a bigger booster and mc for better breaking and figured this would be the perfect time to upgrade. Did my research and saw that a MC from a 91 civic 4dr EX would bolt up just fine without having to bend or reflare for a integra unit and i just might do that since it is larger than my stock one. So my question is does anyone know if that MC will bolt up to a 94+ integra non-abs brake booster?? I know you cant use one from a integra that has abs since the MC im wanting to use dosent have abs. Any ideas? Opinions? Nice ones? Smart ones? PS if you want to talk trash go F$#% yourself!! Lol Help appreciated!!
Old Nov 17, 2010 | 05:16 AM
Former User's Avatar
Default Re: 93 Del Sol S: Will 91 Civic master cylinder work with 94+ Integra non-abs booster
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old Nov 17, 2010 | 06:56 AM
94EG8's Avatar
Seagull Management
No, the whole idea behind using the '90 - '91 EX master cylinder was that it would bolt up to the stock booster so you didn't need to try to find a '94 - '97 RS Integra master cylinder and brake booster. Btw, either of the above works fine, and neither requires bending or flaring lines. I've personally done a couple of civics now using the '94 - '97 Integra master cylinder + brake booster. Also keep in mind the '98 - '01 Units are different (direct bolt on for '96 - '00 Civics) Btw, are you running Integra front calipers? If not using a larger master cylinder will just leave you with a rock hard pedal.
Old Nov 17, 2010 | 09:51 AM
zombieD's Avatar
Crap!! 5-0!! Lol
Oh ok i get it now, thanks for clarifying for me!! and no not at the moment but as soon as i can find a pair of integra front hub assemblies with calipers im going to get them!
mugen_sol
Suspension & Brakes
Nov 9, 2016 06:48 AM
civicsmoke
Suspension & Brakes
Mar 16, 2012 03:32 PM
DMF
19
Jul 22, 2003 09:15 PM
delSolLS
Oct 9, 2002 05:18 PM
