Can you tune for nitrous on Crome? (D16Z6)
Old Nov 16, 2010 | 09:00 PM
DAmnquickDA's Avatar
Default Can you tune for nitrous on Crome? (D16Z6)
Just bought a 93 EJ1. Stock D16Z6. Picked up a set of RC 310's and i have a Zex dry setup laying around. Need to know if crome can account for a nitrous tune (will be tuned by RLZ since they are 5 minutes away) or do i need to shell out money for Hondata or something else. All feedback appreciated. Already searched, dont tell me too.
Old Nov 16, 2010 | 09:14 PM
2k.civic.si's Avatar
Default Re: Can you tune for nitrous on Crome? (D16Z6)
just use a moates 2timer then you can switch between a nos tune and an all motor tune. crome + 2 timer = works fine for nos.
Old Nov 16, 2010 | 09:41 PM
mtber's Avatar
According to a lot of people, you can tune a jet engine on crome. You simply need to write a plug-in for it :-) lol
Talk to RLZ, ask them what they want you to do since they will be the ones tuning it!
Chances are, they will recommend hondata!
Old Nov 17, 2010 | 06:28 PM
One more thing... any opinions as to what a stock z6 with 150K can handle as far as nitrous shot.... reliably. ive tested the limits of high mileage ls motors before an it lasted 1 hour on the street... maybe half a bottle
Old Nov 18, 2010 | 07:29 AM
HAMOTORSPORTS's Avatar
^^ The 2 timer makes it really easy. Just program one map with your regular tune, and make another tune for when nitrous is running. Load each map on the chip (you have to use the offsets to program the chip). If you have a switch turning on your nitrous, just wire it to a relay as well that will send a ground to the 2 timer.
Old Nov 18, 2010 | 08:46 AM
mtber's Avatar
Your LS only lasted 1 hour because you didn't tune it properly. Same applies with any other engine.
Old Nov 18, 2010 | 02:22 PM
I CRX I's Avatar
not to thread jack here but title seems appropriate, how would one tune nitrous using crome? i understand the principle of retarding the timing and increasing the fuel but where would you determine when to stop adding timing or whats the best A/F ratio for nitrous? any tips?
Old Nov 18, 2010 | 04:34 PM
mtber's Avatar
Do some searches on maximum brake torque. http://en.wikipedia.org/wiki/Maximum_brake_torque
google.com is your best friend
Old Nov 18, 2010 | 06:11 PM
eg6b20R's Avatar
Well your looking at about 250hp at the crank. before the rods start to bend on the SOHC Z6. so id say 75 shot well tuned. Stock is about 130hp at the crank.. the reliability is in the tune...
Old Nov 18, 2010 | 09:37 PM
alpha's Avatar
Off topic I guess. But. Who uses Crome any more with solutions like Hondata and Neptune?
Old Nov 18, 2010 | 09:45 PM
people who dont want to get bent over for an overpriced product that just modifies stock honda code tables. there isnt a product out there that can let me tune customer cars for the price crome can.
Old Nov 19, 2010 | 12:35 AM
DDTECH's Avatar
crome is good, but for nitrous i'd go with neptune or ectune, however, you can tune nitrous for crome.
Old Nov 19, 2010 | 04:38 PM
it wasnt tuned at all. zex dry 55 shot 4th gear it died.
the reason i bring up mileage is because ive read that oil in the combustion chamber due to worn out rings mixed with nitrous is a guaranteed recipe for detonation... so i dont want to blow up a well running z6 on account of what may have blown up my last sprayed engine.
thanks again for comments, especially from professional tuners.
how much does that 2 timer thing cost. any links to places selling it?
Old Nov 19, 2010 | 07:26 PM
mtber's Avatar
The two timer is cheap. Check it out on moates.net
Do your self a favor, buy hondata, ectune or neptune with real input/output/nitrous/dual mapping control if you plan on running a lot of nitrous & want the best systems available.
Crome will work, however you get what you pay for :-)
Old Nov 22, 2010 | 04:17 PM
Fair enough im picking up an s300 p28 tomorrow in exchange for a j32a2. Thanks for everyones input. Looking forward to a my first single cam build.
Old Nov 22, 2010 | 06:28 PM
well if he wants the best system available its definetly not hondata, ectune or neptune. but then again how many of use are really willing to spend 4k+ on a motec system or aem.
FA5civicSI
Honda Civic (2006 - 2015)
20
Nov 17, 2008 01:23 PM
95 honda8
Dec 9, 2007 10:25 PM
95accordh22a
Nov 4, 2005 08:45 AM
cornhusker
Dec 17, 2003 08:48 PM
soch vtec crx
Apr 1, 2002 03:55 AM
