Quick Rear Disc Conversion Question
Alright, hopefully i can start on my rear disc conversion tommorow,
I have:
92-95 si complete rear trailing arm and everything, incl. a short line connected to it,
92-95 si e-brake cables,
Accord Euro-R 4040 Prop Valve
What else Am I Missing?
I have:
using stock master cyl, and the accord euro-r prop valve will not work since it has only 4 holes and a normal one has 6 holes :S,,
Also my e-brake cables were to short, I did the whole swap but no e-brake and using stock master cylinder/booster and also stock prop valve, and already i could feel a big difference in the braking,
bought a new prop valve already, now i need to know which e-brake cables will fit, i've read that 94-01 tegs do and 92-95 civic coupe/sedan with rear discs will also fit any1 help?
in an EG it should just be bolt on, I used a complete swap from an SI on my EG DX and it all bolted up fine ebrake cable and everything although the Si prop valve will work too, its not a 40/40
Wait a minute ... Si hatch e-brake cable didn't fit a CX hatch? That's not supposed to happen. They should be a perfect fit.
Well, Del Sol Si/VTEC ebrake cables will be too short.
94-01 Integra will work too. But if your swap came from a 92-95 Civic Si, then the ebrake cables will work, no doubt. But it sounds like you have Del Sol cables.
asianman139608
Oct 26, 2009 07:21 AM
servion
49
May 20, 2005 10:27 AM
goldenk10
Jul 19, 2004 12:54 PM
EGhatched
10
Mar 31, 2004 08:45 AM
