rhd dash parts?
Old Nov 16, 2010 | 03:31 PM
ekcoupeh22's Avatar
Default rhd dash parts?
just a quick question does the rhd carbon dash parts fit into a USDM type R? I bought a stolen recovery type r and i need these parts just need to know if they fit before i buy them thanks guys!
Old Nov 16, 2010 | 03:59 PM
DC4 Rasta's Avatar
Default Re: rhd dash parts?
As far I know the climate control, cup holder, ash tray and the ashtray housing parts that suround the cig lighter will work. The driver side ac vent dont match up and if your going use the other cf pieces like the shifter bezel and the window switches those too will not work. there's a diy thread on how to switch the internals from the window swithes to make those work.
https://honda-tech.com/forums/honda-acura-28/%2Ahow-%2A-jdm-rhd-db8-itr-window-switch-into-usdm-lhd-db-driver-panel-2265073/
hope this helps if you are using the window switches.
Old Nov 16, 2010 | 04:00 PM
DC4 Rasta's Avatar
http://floridahondacrew.com/diy-do-y...-switches.html
heres another one with more pics
Old Nov 16, 2010 | 04:27 PM
BlueIntegraBoy's Avatar
Switches WILL work as is, except the AUTO will be for the wrong window. Passenger switches (JDM/USDM) are interchangeable as is. Driver switch CF plate can be mounted onto a USDM master switch with some dremeling and a drilling of a new hole.
Old Nov 17, 2010 | 05:24 AM
ekcoupeh22's Avatar
lol really dont care about the switches more about the center section of the dash
Old Nov 17, 2010 | 06:18 AM
94rs-turbo's Avatar
you will need the udsm driver vent to look right seen people use jdm one but part facing the door is open, climate, ash tray and cup holder is a stait swap
Old Nov 17, 2010 | 09:08 AM
DC4 Rasta's Avatar
No problem,thought I would share. If your getting it on a deal I would say pick it up. How's the rebuild going?
Old Nov 18, 2010 | 07:42 PM
macef9's Avatar
JDM_nUt
Jul 16, 2009 08:23 PM
eg9
Nov 1, 2007 07:01 PM
Soichiro's way@MF
Sep 10, 2005 09:29 PM
ChapR
Jan 19, 2003 11:20 PM
Booker T
Oct 18, 2001 06:13 AM
