99 Civic Si - heater doesn't work after stereo was stolen
Old Nov 16, 2010 | 02:34 PM
si_23's Avatar
Default 99 Civic Si - heater doesn't work after stereo was stolen
Hi everyone, I have a honda civic si 1999, and my heat doesnt work so well. It stop working so good after my car stereo was stolen. The theives kind of took out my whole heating control thing, so i had to force it all back together. I also changed the thermostat and that helped a little bit. Does anyone know what else I can check to fix my heat. My heat is basically not so hot, the heat is warm air only. Mostly warmer on the vent that is located on the drivers side. Thanks.
Old Nov 16, 2010 | 03:23 PM
Former User's Avatar
Default Re: 99 Civic Si - heater doesn't work
While figuring out how to fix the problem, you can manually open the heater hose valve on the firewall to get some heat in the cabin:
Old Nov 16, 2010 | 08:05 PM
si_23's Avatar
Default Re: 99 Civic Si - heater doesn't work after stereo was stolen
Are u sure this is gonna work? I never touched anything in the first place.
Old Nov 17, 2010 | 04:06 AM
grumblemarc's Avatar
The Grumpiest
The thieves obviously did. Try it. It's a simple thing to do.
Old Nov 17, 2010 | 04:35 AM
Jockone's Avatar
Try what RonJ said worst that can happen is nothing gets better.
Then check if something has been knocked loose by the thieves tearing out the radio and the heater panel.
Old Nov 17, 2010 | 11:07 AM
jdmcivicracer89's Avatar
did u take out ur whole center counsil??? there r wires that connect to it that come close to the radio they might of knocked em loose
Old Nov 17, 2010 | 02:17 PM
si_23's Avatar
Yea I did take the whole thing out, but I have no idea which wires to mess with. I'll just try what the diagram saids and give u guys an update. thank a lot.
Old Nov 17, 2010 | 04:47 PM
TheJGB3's Avatar
Since the 99-00 Civic went to an electronic CC (for the hot/cold **** vs the manual cable slider that the 98 & older civics had) so the thieves did something to your wiring messing it up.
pinoysi2000
Oct 27, 2012 09:39 AM
greg51
Oct 10, 2011 05:52 PM
greg51
Jun 18, 2011 09:52 AM
peterislazyek9
Jan 5, 2008 11:31 PM
herovueboi
Oct 18, 2004 06:56 PM
