2 questions about b16A tranny problem and ecu trouble code
Old Sep 21, 2002 | 07:04 PM
Snail Tuning's Avatar
Default 2 questions about b16A tranny problem and ecu trouble code
I did a b16a sir1 swapp in a 91teg. the tranny goes n gear but doesn;t move doesn;t even grind. i adjsted the cable manytimes and it won;t move or even grind. anyway to fix it? did i add to much fluid not enough? is my clutch shot?
when i put the tranny in gear and let the clutch out nothing happens! when i put the tranny ingear without using the clutch nothing happens! When i loosend the clutch cable becuase i thought it might be to tight and then i put it in gear still nothing happens! no grinding no noises nothing it just goes right in and doesnt move. I NEED HELP!
im pretty sure their is a clutch in it because it moves just the the old teg motor.
also the ecu is showing a code 22 2 long flashes and 2 short whats that mean and how do i fix?
[Modified by bmcc72, 9:33 PM 9/22/2002]
[Modified by bmcc72, 9:35 PM 9/22/2002]
Old Sep 21, 2002 | 07:19 PM
VTECVillain's Avatar
Default Re: 2 questions about b16A tranny problem and ecu trouble code (bmcc72)
If you got a full B16 swap, did you separate the tranny from the motor before the install? Since it's already in, I know it's a pain but I would tear it off and start from there. I've know 2 people who ordered swaps that never came with a clutch although it was together, one guy never even got the flywheel! Code 22 is the VTEC pressure valve.
blazzer
27
Nov 5, 2013 03:45 AM
JDM_Si_EG6_FTW
Feb 5, 2010 09:42 AM
tangerinebeast
Sep 9, 2006 10:26 PM
reeder321
12
Dec 31, 2003 07:29 AM
