obd2 JDM LS throwing o2 sensor CEL code
I need an O2 sensor im throwing a CEL for it. it an ob2 JDM LS would i just have a to get a pre-cat o2 sensor? Not sure only because its jdm
the ECU tells you what it uses. If it's a JDM ECU, you only have a primary O2.
it will also be a different code for primary(pre-cat) vs secondary(post-cat).
how do you know that you have a code for the O2? (which code is it?)
i have a modis. it was heater circuit malfuntion. the motor only has on o2 sensor and yes it is a JDM ECU. na di have a code for high voltage on the IAT
replace pre-cat O2 since you only have one O2.
high voltage on IAT, make sure you didn't swap the IAT and EVAP purge solinoid plugs.
Where did you put the IAT (I'm assuming you have 96-00 Civic which has the IAT in the airbox or intake arm) or did you wire up a round style plug?
