b18 bad gas milage
Old Nov 16, 2010 | 08:24 AM
EF9_RIDER37's Avatar
Default b18 bad gas milage
what up guys this is whats up i have a b18b in my car converted to obd0 and it runs great the only thing is that when i fill up the car with gas by the first couple of minute im really low if i fill it up to the full line by 30 minutes or more im already half way to the middle line. i just replaced spark plugs a while back did oil change radioator flush, and head gasket replaced,new seals installed and i dont know why the gas is going down so low injectors are good. i a little stuck and dont have time time to work on the car and search i have to be at school all day a little hepl would be cool thanks guys
Old Nov 16, 2010 | 08:36 PM
rbjeepthing's Avatar
Default Re: b18 bad gas milage
Ok so I took the liberty to edit you post so people could read it and then maybe they might help
I have a b18b in my car converted to obd0 and it runs great the only thing is that when I fill up the car with gas by the first couple of minutes i'm really low. If I fill it up to the full line by 30 minutes or more i'm already half way to the middle line.
I just replaced spark plugs a while back did oil change, radiator flush, head gasket replaced and new seals installed. I don't know why the gas is going down so low injectors are good. I'm a little stuck and don't have time time to work on the car and search. I have to be at school all day a little help would be cool thanks guys
Mileage? Like "x" amount of miles to middle line?
30min of straight hard driving at the track and i'm under 1/2 a tank
Old Nov 17, 2010 | 08:35 AM
thanks foe the edit sorry about that and yeah ive been driving the car around and my gauge goes down pretty fast i fill it up with 20 dollars say on a thursday and by monday i need to fill it up again
Old Nov 17, 2010 | 01:18 PM
^again mileage numbers are key.
In 4 days of driving you could easily use up $20 of fuel. Fill your tank up set your odometer to zero and report back with how many miles you get to that full tank. Without that no one is going to be able to help you.
Old Nov 17, 2010 | 05:25 PM
DumpdEJ6's Avatar
I like the tuna here
This seems to be a common misconception...I've asked people about their gas mileage, and almost every one gives me a response like "It only takes X amount of dollars to fill up", or "I get 300 miles to a tank". WTF people? Does no one know how to calculate gas mileage anymore?
/rant
Old Nov 22, 2010 | 08:28 AM
aite these are the number so dar i got 24.6 on the metter with the gauge reading at almost half
Old Nov 22, 2010 | 11:00 AM
DumpdEJ6's Avatar
So you're getting approx. 50 miles to a tank?! 5mpg!? Holy sh*t brah, that IS bad. I wouldn't think your car would even run with that rich a fuel mixture...are you sure your gas tank or fuel lines aren't leaking?
soccerboo
Oct 14, 2012 04:20 PM
coco718
33
Oct 4, 2011 12:09 PM
vtechjunkie
Dec 12, 2008 03:14 PM
type Gendy
Oct 12, 2003 09:05 AM
kikkoboyie
Oct 30, 2001 08:09 PM
