96 Civic/GSR swap - Are pre- and post-cat O2 sensors the same?
Old Nov 16, 2010 | 06:34 AM
dices543's Avatar
Default 96 Civic/GSR swap - Are pre- and post-cat O2 sensors the same?
I have a 96 Civic with a GSR swap. I'm going to be replacing the o2 sensors. I've been doing some research and i'm a bit confused. Some sites say that you can use two of same o2 sensors for pre-cat and post-cat. Other sites say that they are different.
Can i buy 2 of the same O2 Sensors or do i have to buy two different O2 Sensors(pre-cat and post-cat)?
Old Nov 16, 2010 | 07:35 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: O2 Sensor Question
there is a reason why both pre and post cat sensors are dif looking/price/part #s.
i jus put in a secondary for a guy on accident for a primary....still got the primary o2 CEL/ crome has 2nd o2 disabled.
unless sum1 can PROVE otherwise dont listen to their nonsense
Old Nov 16, 2010 | 08:00 AM
jayWknight's Avatar
They are both the same type of oxygen in sense of how they function, narrowband. They only differ because of wire length and connector type.
Rick, I don't understand what you are saying that crome has 2nd o2 disable? Crome is obd1, therefore there isn't a second o2 sensor. Crome can only disable the primary o2 sensor and is the only o2 sensor in obd1 ecus.
Old Nov 16, 2010 | 08:04 AM
I'm not Rick!
96 civic with swap..obd1 conversion. it basiclay jus disables the CEL for it.
the 2nd o2 sensor is only a heater sensor. if the cat gets over heated or back up it will throw a CEL.,
Old Nov 16, 2010 | 08:08 AM
jayWknight's Avatar
Well the OP is obd2 because he asking about pre-cat and post-cat o2 sensors. Well instead of saying disable, obd1 eliminates the secondary o2 sensor.
Old Nov 16, 2010 | 11:32 AM
dices543's Avatar
So its the same, i can just buy two of the same and extend the second o2 sensor wire. Correct?
Old Nov 16, 2010 | 11:38 AM
Former User's Avatar
No, this is not correct. It's an O2 sensor with a heater element.
blackccoupe
Feb 28, 2010 03:47 PM
gsr336
Nov 12, 2007 12:11 PM
XSlackerX
Dec 30, 2003 06:30 PM
Qwikrex
Jul 31, 2002 09:53 PM
