want to beef up my valve train
Old Sep 21, 2002 | 05:58 PM
TurboBumblBee's Avatar
Default want to beef up my valve train
I just want some suggestions for what type of titainium valves, valve sprins and retainers i should get and about how much im looking at the other thing that i need to do is my piston rings or seals what type should i look to invest my money in
Old Sep 21, 2002 | 06:07 PM
98itR484's Avatar
Default Re: want to beef up my valve train (95CivicEX)
how much power you want to make??
what type of cams??
what do you want to rev too??
Old Sep 21, 2002 | 06:12 PM
Default Re: want to beef up my valve train (98itR484)
rev wise not really doing much more internal to the motor im just trying to prep it to turbo it with in the next coupleof weeks only thing i know i will be doing is p28 chipped ecu by the way the car is a 93 hatch with a b18c
Old Sep 21, 2002 | 06:15 PM
ZygSpeed's Avatar
If you're not planning on reving more than stock redline, then there's no reason to do much of anything to the valvetrain.
Now, it's a different story if you're going to be doing bigger lift cams and/or a higher redline. HTH
[Modified by Zygspeed, 10:16 PM 9/21/2002]
WalkerGSR1
Jun 24, 2007 07:00 PM
crexer
Jan 6, 2003 06:10 PM
JDMCIV95
Nov 22, 2002 07:47 AM
migo
Nov 13, 2001 11:14 AM
