95 eg coupe mini-me with D16Y5 head?
ive got a 95 eg coupe that im turning into a street/strip car and im wanting to do a built mini me boosted. i have a y5 head that is built with stage 3 everything and a b7 block. is this a a good combo or should i use a different head such as a z6, y8, etc.
The D16Y5 is a horriable head to swap on the B7 block. I don't even know if it will run correctly since the D16Y5 is a Vtec-E. Your best luck is to find a Z6 if you are boosting or a Y8 if you are going all motor.
Search before doing anything also.
