tranny fluid same as brake fluid???
Old Sep 21, 2002 | 05:45 PM
-BlueGSR-'s Avatar
Default tranny fluid same as brake fluid???
As the topic says...is it the same?? i need to flush both of them soon...
Old Sep 21, 2002 | 05:46 PM
LeftCorner's Avatar
Default Re: tranny fluid same as brake fluid??? (GS-ssbp-RRR)
Nope, not even close.
Old Sep 21, 2002 | 06:09 PM
ingrate's Avatar
25 Year Member
Default Re: tranny fluid same as brake fluid??? (LeftCorner)
just to clarify.. the brake and clutch hydraulic system both use brake fluid.. but for the tranny case itself you use gear oil. preferably honda MTF
Old Sep 21, 2002 | 06:16 PM
-BlueGSR-'s Avatar
Default Re: tranny fluid same as brake fluid??? (In7egrity)
oh ok makes so much more sense now!!...so the clutch fluid is dot 3 right? and the transmission fluid you use honda mtl....How often do i need to replace this fluid??
Old Sep 21, 2002 | 07:46 PM
Sima's Avatar
Default Re: tranny fluid same as brake fluid??? (GS-ssbp-R)
Acura recommends you change the tranny fluid at no more than 15K. Even though I don't drive my Integra everyday or hard, I change mine every 10K to keep it tiiite.
Old Sep 21, 2002 | 10:48 PM
RedGSR's Avatar
Default Re: tranny fluid same as brake fluid??? (Sima)
wow... you need to get a host that long.... I saw the dealer using a suction pump, so I just went and bought one. I could never find a furnel that is long enough.
Old Sep 21, 2002 | 10:53 PM
TurbothisLS's Avatar
tranny fluid no, clutch and brake fluid are the same.
Old Sep 22, 2002 | 02:43 AM
brad.'s Avatar
wtf
Old Sep 22, 2002 | 06:45 AM
DR. ON POINT's Avatar
Banned
Default Re: tranny fluid same as brake fluid??? ([626]JDM-b16a-EF9)
make sure u ONLY use honda MTF
Old Sep 22, 2002 | 08:27 AM
GSRaCeRbOI's Avatar
Default Re: tranny fluid same as brake fluid??? (On Point EK)
like others have already pointed out... clutch and brake systems both use brake fluid.. the actual transmission/gear box I use honda MTF...
as for the funnel w/ a hose.. you can make one.. just go to home depot and buy some flexible clear vinyl tubing (2' or so should be fine) to whatever diameter fits the bottom of your funnel.. you might also want to buy a hose clamp (its like $1 or so) to clamp the vinyl hose securely to the funnel just so it doesn't "accidentally" slip off the hose and cause a big mess.... the hose should be like $0.50/foot max .. and the hose clamp should be like $1 or less...
I bought a pump at the store for about $4 that pumps straight from the bottle... at the end of the pump is a clear vinyl hose thats about 2 or 3 feet long.. either would do the job..
Old Oct 5, 2002 | 07:16 AM
integra-modder's Avatar
Default Re: tranny fluid same as brake fluid??? (GSRaCeRbOI)
how hard is it to change?
how long does it take?
whats involved?
also, how much is the honda MTF stuff?
Found a link for some guidance.... http://hazone.com/default.htm?howto/btrannyoil.htm
[Modified by integra-modder, 1:16 PM 10/5/2002]
globy123
Sep 27, 2009 05:32 PM
B16AGUY
Jul 13, 2009 03:01 PM
cash459
Acura TL, RL & ZDX
Feb 7, 2009 08:21 AM
explictness
Feb 21, 2007 08:37 PM
Thrillhouse
Oct 19, 2002 08:42 PM
