FS: '91 CRX Si - SCCA Solo CSP/(ITA-potential)
It's SOLD!
Yup, not exactly wanting to sell the car, but in order to move on with the new one, I've gotta free up some money somehow...
Some history, I bought the car from the second owner, who had moved to New York from California a few months before I bought it- good shape, none of the 'usual' rust that plagues most CRX's. The car had previously won the MoHud SCCA Solo2 CSP championship - also has placed well in numerous regional and national events.
Current motor - D16A6 - has ~10-20K miles on it - last compression check on it (last spring) put all four cylinders around 210 (+5/-5). 3-4 years ago, it was bored 0.020 over, new pistons/rings/crank&rod bearings/gaskets/etc. It has the OEM 5-layer head gasket, with ARP studs. Head has been shaved, only about half of service limit. Rotating assemblies balanced. AEM cold-air intake, DC Sports 4-2-1 header with rear/top mounted Innovate LC-1 wideband O2 and controller. PM6 ecu is socketed/chipped; have everything needed for flashing/programming/datalogging/eeprom-emulation. Hayame 2.25" catback with longitudinally mounted muffler w/ removable insert;no-name hi-flow cat. Intake manifold is off a D16z6 (which has been bored/honed to match) the throttle body from a JDM B16A. *6-puck clutch with Fidanza 8-lb flywheel. OBX helical LSD installed to original 5-spd transmission with new diff bearings/seals/etc.
Corbeau Forza driver & passenger seats, custom harness bar with 5-pt harnesses (driver's is a Impact! Racing-current, passenger's is a RJS-not current). Full urethane 'master' kit from Energy Suspension installed, as well as extra bits from Prothane for rear compensator arm (rear trailing arm front links) and motor & tranny mount inserts. Front sway bar has been removed, but will be included. Rear sway bar is a 22mm adjustable Suspension Techniques w/ spherical bushing endlinks. (No-name) Ebay front and rear lower tie bars installed. Koni yellow/sport single-adjustable shocks, Ground Control coilovers w/ Eibach ERS springs - 600F/600R.
Front brake pads are Hawk HP+ blacks (autocross, low temp), rears are semi-metallics. OEM-style front & rear rotors.
13x8.5 Panasport C8-13's with 215/50/13 Kumho V710's mounted (about a half a season of use). Other OEM wheelsets (teardrops, sawblades, etc.) included with other tires, 195/55/14 Kumho V700's, old Hoosiers A6's, etc. etc.
Couple of video clips- from ACC autox:
http://video.google.com/videoplay?do...18561302349740
From NER/Devens event:
http://video.google.com/videoplay?do...98836451155754
Extra D16A6 motor, tranny, other misc parts, seats, harnesses, etc. Also included, unfinished 'homemade' ITB setup using no-name intake runners with CBR1000RR ITB's/injectors/wiring/etc., Golden Eagle vacuum log, lines, etc. complete setup for OBD0->OBD1 conversion - socketed P28 ecu, non-vtec distributor from a OBD1 D15B7, all harness adapters (rywire) needed for installation. I also have all the original interior parts as well. Tons of other stuff I can't think of off the top of my head, but in piles.
Changed prices and equipment - $2500, see below- Any questions at all, please feel free to ask- thanks in advance.
-Lyndon
-Lyndon
Still for sale, entertaining any remotely reasonable offers!
***UPDATED***
I've swapped around some parts in order to accommodate a potential buyer, but after swapping parts, a test drive, and a "I'll have to think about it"- here's the current config and price:
-Koni/GC setup swapped out for OEM springs/shocks
-Corbeau seats, harnesses, and harness bar swapped out for stock '91 Si seats
-AEM intake swapped out for stock intake/airbox
-reinstalled front sway bar
-Innovate LC-1 WB swapped out for new stock O2 sensor
Link to newest pictures:
http://s163.photobucket.com/albums/t..._pics_resized/
As the car sits, equipped with the short update list above (no extras):
$2500
If there is interest in the car, as stated above, or interest in additional parts, installed or included from the list of extras, please ask and we can work something out.
A semi-saddening plug- this car has been averaging around 40mpg; would make an excellent daily if someone were so inclined.
Also taking offers on individual parts.
***UPDATED***
$2500
For all those who requested hi-res pics:
http://s163.photobucket.com/albums/t...view=slideshow
Short video clip of cold start and interior:
http://www.youtube.com/watch?v=JvjJkokriRg
kidrsx03 - pm sent.
project777 - if I had another honda, I'd be interested, but I'm unloading the last of my hondas. Thanks though!
wow I'm surprized this hasn't sold yet pm me so we can discuss a little more about everything very interested always wanted to get another crx si.. thanks
scramblerman
Mar 9, 2004 04:10 PM
