Wastegate spring 1,2 bar 17psi help
hi from germany
i will drive 1,2bar boost 17psi?
i have now 1.000 14.504 Large Blue 2.360
and 0.600 8.702 Small Blue 1.875 In SPRING
how much i must cut the small 0,6bar 8psi spring to get about 17psi 1,2bar boost???
cut the half 50% from the spring ore more? like 80%??
correct is two spring 0,4 bar spring and 0,8 bar to get 1,2 bar
can i use my methode????
infos
0.250 3.626 Small Yellow 1.875 In
0.400 5.802 Small Red 1.875 In *******************
0.500 7.252 Small Green 1.875 In
0.700 10.153 Large Yellow 2.360 In
0.800 11.603 Large Red 2.360 In *******************
0.900 13.053 Large Green 2.360 In
1.100 15.954 ** ( ex. Lg Yellow + Sm Red ) Small + Large
1.200 17.405 ** ( ex. Lg Red + Sm Red ) Small + Large
1.300 18.855 ** ( ex. Lg Green + Sm Red ) Small + Large
1.400 20.305 ** ( ex. Lg Blue + Sm Red ) Small + Large
1.500 21.756 ** ( ex. Lg Blue + Sm Green ) Small + Large
1.600 23.206 ** ( ex. Lg Blue + Sm Blue ) Small + Large
infos
No, do not cut anything. Mix and match the spring colors to achieve the desired boost pressure. At most you can add shims to increase the spring pressure if slightly below your target.
wrx'n you
Dec 15, 2006 05:13 PM
turbo*s2k
Oct 14, 2006 07:21 PM
turbo*s2k
Northern California (Sales)
12
Oct 13, 2006 02:46 PM
DSRxSALSA
Mar 30, 2004 06:58 AM
