92 Civic hatchback Si - starter won't crank engine
Old Nov 14, 2010 | 08:25 PM
023's Avatar
023
Default 92 Civic hatchback Si - starter won't crank engine
I have a 92 honda civic hatchback si with the stock D16. When I go to start the car all the lights on the cluster come on but nothing else happens when I turn the key to start the car. I checked the batt. and changed the starter it worked for a few days but now the same problem is occuring again? not too sure what the problem is I looked over some ground wires but everything looks good. Any suggestions would be REALLY helpful Thank you.
Old Nov 14, 2010 | 08:30 PM
Former User's Avatar
Default Re: not starting
Check whether the rubber stopper (red arrow) for the safety starter switch at the top of the clutch pedal is broken or has fallen out.
Old Nov 14, 2010 | 11:06 PM
D3vin's Avatar
Default Re: 92 Civic hatchback Si - starter won't crank engine
Check if your engine and battery is grounded correctly. Also your master relay switch? (Dunno correct name) It's the clutch switch when you press it down so the starter will prime unless you bypassed it.
Old Nov 15, 2010 | 08:34 PM
023's Avatar
023
Thank you so much guys I really appreciate the help!!! Yes it was the safety starter switch at the top of my clutch pedal It was out of place so there was no contact between the two. Thank you guys again!!
s.langley
Feb 3, 2019 06:31 AM
Amanda7289
Dec 31, 2014 11:37 AM
R2Andy
Aug 22, 2012 03:41 AM
stl eh2
Dec 3, 2009 10:07 AM
fullboostin
Jan 4, 2008 03:49 PM
