Normal Blow By?
Hi guys, I have a b18c5 motor that was rebuilt 30,000kms ago and when I take the oil filler cap off the valve cover (while car is running) there is air blowing out which I can feel if I place my hand around 25cm above the hole, Is this a normal amount? No smoke from exhaust, no oil in coolant or coolant in oil. no oil spraying out the pcv or oil cap
there is no blue smoke nor is the car running poorly, compression seems fine without needing to be tested. I wasnt worried by it until a mate said that a little air is ok but I can feel it around 20cm above the oil filler hole and thought that may be over normal
you have some blow by obviously. get a compression tester that cost $30-$50 and get some real numbers instead of guessing
ahh your a human compression tester. perfect now I can just send you a video of my motor running and you can give me my compression numbers across the board.
itsJDMyo
10
Aug 26, 2004 12:16 PM
TeamCracka
Feb 23, 2004 12:28 PM
