91 dx hatch missfiring after a fixing a blown headgasket
Old Nov 14, 2010 | 08:14 AM
949's Avatar
949
Default 91 dx hatch missfiring after a fixing a blown headgasket
im getting that seems like a missfire after fixing a bolwn headgasket.
i am assuming its the dizzy. could it be the cap and rotor is bad or something else?
it starts up, but not right away everytime. when it does start up, it sounds like a lawn mower on but for a few moments during a drive it drives normally. im thinking that the firing of the sparks is not consistant. checked the compression and the compression is about 110.
Old Nov 14, 2010 | 08:18 AM
FSRslug's Avatar
Default Re: 91 dx hatch missfiring after a fixing a blown headgasket
Did you set the ignition timing?
Old Nov 14, 2010 | 08:44 AM
949's Avatar
949
yeah it should be at the correct degree, i used a timing light on it. right dead on between the 3 lines, i believe its red for the center line color.
Old Nov 14, 2010 | 09:13 AM
Ludster's Avatar
Put your motor at TDC and make sure your cam lines up accordingly
Old Nov 19, 2010 | 07:15 AM
949's Avatar
949
thanks guys.
figured it out.
it was a bad dizzy.
Old Nov 19, 2010 | 08:50 AM
macef9's Avatar
gsr_b20b
13
Mar 10, 2015 09:33 PM
dubyas1989
Nov 13, 2013 11:18 AM
big_daddy234
Dec 3, 2009 05:20 PM
slowslow
11
Apr 29, 2008 11:34 PM
adler
Sep 15, 2004 05:55 PM
