93 Civic Hatch/D15b non-vtec swap - What ECU is best?
Old Nov 13, 2010 | 04:30 PM
98bucket's Avatar
Default 93 Civic Hatch/D15b non-vtec swap - What ECU is best?
(not my thread i made it for a friend)
its a right hand drive 93' Civic Hatch, it stopped working outta no where, they replace the dizzy, and the p06 ecu, the stock ecu was fried..... should she try a diffrent ecu? p08?
Old Nov 13, 2010 | 09:22 PM
98bucket's Avatar
Default Re: D15b non vtec ECU got fried?
bumper
Old Nov 14, 2010 | 05:50 AM
foo fighters's Avatar
the p08 is for the jdm d15b v-tec,and the p06 is for d15b7 non v-tec. you got V-TEC or NOT??
Old Nov 14, 2010 | 10:14 AM
98bucket's Avatar
Default Re: 93 Civic Hatch/D15b non-vtec swap - What ECU is best?
No vtec man.
Old Nov 15, 2010 | 07:05 AM
do you know what motor it is? is it fuel injected? P06 will fix it as long as it still has a d15b7.
Old Nov 15, 2010 | 07:06 AM
what exactly is wrong??
Old Nov 15, 2010 | 09:08 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Was the stock ECU actually fried, or did the shop just say that to cover their asses when they replaced the ECU, and the car still didn't start?
Whomever is diagnosing this vehicle needs to check for fuel and fire to see which is missing, and possibly even check to see if the timing belt is broken by having someone spin the engine over while another person watches the cam (look into the oil filler cap opening in the valve cover) to see if it's moving.
There are a ton of possibilities as to why that Civic would just stop running, and not start back up:
Spark:
- Coil
- Igniter
- CYP/TDC sensor in distributor
Fuel:
- Main relay
- Fuel pump
Electrical:
- Ignition switch pigtail
- Grounds
- ECU
- Wiring/Fuses
lilboxx
Engine Management and Tuning
Sep 29, 2018 08:21 AM
1990CamaroRS
Dec 27, 2009 03:43 PM
robs93civic
Apr 12, 2006 12:52 PM
mOvingviOLaTiOn
Aug 29, 2005 09:00 PM
