94Accord D4 Code:15
For some reason after a transmision change to Honda's ATF my car would run fine for 10minutes all gears shifting,after 10minutes now its struggle to shift into i believe 1st or 2nd gear. On Drive 4 (d4) it stays around 1-20mph at high RPMs (4-5k redline sometimes ) till it just stays to 0mph and doesnt go anywhere. however on Drive 1 (D1) It can go 1-30 without using so much rpms average around 3k rpm however that also stops to till it hits 0mph no drive. I checked both NM (Main shaft) SS and NC SS (counter shaft speed) and both check 550ohms out side and inside where its conected to the TCM/TCU. I replaced it with a used TCM and ECU still no difference, same outcome. I also hear a odd sound (like a whirling sound?) when in park and once the computer adjusts i dont hear it anymore or not as much. the only drive that works is Reverse without struggle. I would turn off the engine and turn it back on around 10seconds i can get the engine to drive a bit till it goes off and the same code 15 will pop again with the short service tool in. I have checked the TPS, Selonoids everything checks ok.
Everycheck i would reset the ecu/ecm tcu/tcm and once i drive it a bit the code 15 pops.
And ECU has both the oil, battery and engine light constantly on with the service tool on. (if this helps any)
Enixero
Aug 10, 2011 12:13 AM
crazyskiier3989
Feb 19, 2010 06:53 AM
