Ls trans B16 clutch?
Old Nov 13, 2010 | 11:17 AM
AllMotorAri's Avatar
Default Ls trans B16 clutch?
I have a 91 ef and I was wondering will a 90-91 ls trans line up with a b16 clutch?
I tried putting a gsr trans in but it wouldn't fit the clutch.
Old Nov 13, 2010 | 01:22 PM
EF-Devotion's Avatar
Default Re: Ls trans B16 clutch?
yes and no. yes if you use a b16 clutch that from cable b16 trans. no b16 from hydro trans will not fit.
Old Nov 13, 2010 | 03:02 PM
Deetz's Avatar
Crazy Honda Guy
No, that is "not" how it is!
Cable trans-
90-91- small spline mainshaft
92-93- large style mainshaft
Hydro Trans-
94-01- ALL large style mainshaft
So basically all 92+ b series clutches are interchange
and "all" years 1990-2001 have the same pressure plate, just a different clutch disk for the small 1990 and 91 models
Old Nov 13, 2010 | 08:10 PM
speedy86's Avatar
WOW GOOD INFO!!!!!!!!!!!
Old Nov 14, 2010 | 01:47 AM
Cable trans-
Hydro Trans-
so you saying a cable b16 clutch will not fit the 90-91 trans. because you are wrong. b16 cable will fit. all hydro and 92 up will not fit 90-91, but a cable b16 will. 90-91. i lnow cause i got a gsr cable trans.
Old Nov 14, 2010 | 05:22 AM
Deetz's Avatar
Crazy Honda Guy
I thought i was clear on this!
Hydro started in "1994" NOT 1992
There are "two" B16A clutches:
- 90-91 (small spline)
- 92+ (large spline)
So, if you have a 1990 or 91 Tranny, you need any 1990-91 B series clutch to fit your cable transmission
Oh, and btw, the "GSR" didn't some out till 1992. Yes it is cable as i have stated twice already, it will use any b series clutch from 1992 onwards. I have have cable YS1 in my own crx, it is large spline
Old Nov 14, 2010 | 09:21 AM
Thank you
Old Aug 14, 2012 | 10:16 AM
XxjohnnybravoxX's Avatar
Ok, I have a B16a swap w/ a YS1 tranny and I need to put a new throw out bearing shift fork in it and a clutch but idk what kind of clutch or axles to but for it. The car is a 90' crx please help!
apbtwhiskey
Transmission & Drivetrain
Jun 8, 2013 04:46 PM
hatchet_honda
Mar 30, 2011 05:58 AM
90 JDM EF8
Sep 20, 2009 01:45 PM
WWTeg
Dec 20, 2008 07:17 PM
ole' black crx
Apr 9, 2008 06:26 PM
