PO700, PO715, PO730? - 1999 Auto LS
My brothers 99 Integra Automatic LS is throwing PO700 PO715 and PO730. I searched for what it could be but i can't find anyone saying what worked for them. Some places are saying Linear Solenoid and some say mainshaft speed sensor but no one is saying what worked for them. The car shifts rough through the gears. I know that the po700 is because of the po715 and I'm guessing the po730 is because of po715 also. Can anyone with some experience help?
Do the easy stuff first, check the sensors for resistance and compare it what it should be, check the wires between the sensors and TCM for continuity, check for continuity between the wires and each, as well between each wire and ground. If that all checks out borrow another TCM and ECU if you can. If all that checks out chances are pretty good the tranny is bad (which is actually usually the case when you start getting automatic transmission codes in honda, sensors and wiring don't go bad nearly as often as the transmissions themselves do.
jwaked
Mar 16, 2006 03:49 PM
KiNG $h!t
Aug 28, 2003 09:29 PM
