NEW From Sema 2010 - Innovate MTX-L ALL IN ONE WIDEBAND GAUGE
The new Innovate Motorsports Digital MTX Series Air/Fuel
Ratio Gauge utilizes the only 100% digital Wideband
air/fuel ratio technology on the market! The patented
Direct Digital™ technology we use is faster and more
accurate than common “UEGO” gauges and is now more
affordable! In addition, the gauge features a water
resistant casing, interchangeable faceplates and bezels,
and 2 fully programmable linear analog outputs for use with
aftermarket engine managements systems and dataloggers!
• The only 100% digital wideband air/fuel ratio technology!
• Water Resistant 52mm (2 1/16”) round dash-mountable casing is perfect for automotive, powersports,
marine, and demanding racing applications
• Built-in Direct Digital™ Wideband Controller reduces wiring and simplifies installation
• Wideband O2 Sensor is compatible with all fuel types (Leaded, Unleaded, Diesel, Methanol, E85, etc)
• Ability to calibrate O2 sensor for increased accuracy
• (2) 0-5v fully programmable linear analog outputs for use with
engine management systems “closed-loop” and external dataloggers
• Interchangeable faceplates and bezels: Black and silver bezel,
black and white faceplates included
• Large digital readout and programmable “Digital Needle” provides
the functionality of a needle style gauge with the pinpoint accuracy
of a digital display
• Datalog using LogWorks on your PC
• Serial IN and OUT ports allows for easy connection with other
Innovate MTS and other devices
3844 MTX-L: Air/Fuel Ratio Gauge Kit, Includes Harness
Pricing: $199.99
getting very high 20.9 on gauge and fluctuates up and dwn.can i get pin out for p28 obd1 on b20b w/vtec in 1998 civic ?
KStuned
Oct 6, 2004 11:39 AM
