obd0 or obd1?
Old Nov 12, 2010 | 10:51 AM
88EDHatch's Avatar
Default obd0 or obd1?
How do I tell? its been swapped to a jdm D15b vtec.
Old Nov 12, 2010 | 10:52 AM
hybridmiklo's Avatar
Default Re: obd0 or obd1?
check which ecu you are using
Old Nov 12, 2010 | 10:59 AM
88EDHatch's Avatar
ok another question. i got the wrong dizzy on it(it leaks oil because it doesnt line up)im going to get a z6 dizzy for it sat. if it is obd0 can i still run a obd1 dizzy no prob?
Old Nov 12, 2010 | 11:00 AM
88EDHatch's Avatar
also the dude I got it from said its the wrong ecu as well and thats why it throws codes
Old Nov 12, 2010 | 11:12 AM
jlicrx's Avatar
OBD0 ECU requires use of OBD0 distributor and OBD1 ECU requires use of OBD1 or OBD2 distributor - you can't mix and match
Old Nov 12, 2010 | 11:23 AM
88EDHatch's Avatar
well is there an obd0 dizzy that will fit?
Old Nov 12, 2010 | 11:27 AM
jlicrx's Avatar
no
whitecivic11
Mar 28, 2010 11:04 AM
crxsteve
Aug 10, 2007 03:15 PM
dougshatch
Jun 14, 2007 12:41 PM
Maddox
10
Apr 11, 2004 11:24 AM
seerxsi
13
Mar 26, 2004 06:37 PM
