Eagle rods for B18c1
Old Nov 12, 2010 | 07:32 AM
AlAddiN|502's Avatar
Default Eagle rods for B18c1
On the website it shows B18c Vtec but not sure if they are long enough for a gsr bottom end ?
http://www.eaglerod.com/index.php?op...d=21&Itemid=32
Part Number 5394.BHO
Old Nov 12, 2010 | 08:13 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Eagle rods for B18c1
NOTES:
standard rod for B18A, B18B, B20B, B20Z. Older design used 5/16" bolt (3/8" head) - torque was 28 ftlbs with moly lube.
This was in the bottom of the page in the *notes* section. This means that the rods you are looking at are for the NON-VTEC B series engines listed. They can be used in a B18c IF you're running an LS crank. GSR crank requires the proper Eagle rods for that application.
Old Nov 12, 2010 | 08:21 AM
Figured, just to make sure. Thanks
speedciv
Jun 22, 2013 11:15 AM
AlAddiN|502
Nov 12, 2010 07:55 AM
RACING INTEGRATION
Oct 27, 2004 02:16 PM
7rrivera7
May 24, 2003 01:29 PM
atmo_monster
Apr 30, 2003 02:34 PM
