high idle and stumble
Old Nov 11, 2010 | 08:41 PM
chirrin's Avatar
Icon2 high idle and stumble
hi guys im new on this honda stuff ill try to explain myself im a spanish speaker and sometimes i have hard time explaining myself ok.. here we go
i have a 1992 honda accord ex
when im turning the car on when cold is hard i have to give it couple of trys and step a lil on the accelerator
when car turns on it stay at 1000 rpm but when is getting warm up goes up to 1500rpm and that how it stays while in use (doesnt supose to be backwards when u turn it on goes to 1500rpm and when gets warm goes down to 1000rpm?)
sometimes i accelerate when driving and stumbles
check engine light is on too
any advice? thank u guys
Old Nov 11, 2010 | 10:02 PM
brakedrum's Avatar
Default Re: high idle and stumble
You need to read the code that the lit Check Engine Light indicates has been stored in the computer. Use a bent paper clip to jumper the small blue connector that you will find tucked under the dash on the passenger side. You'll know its the right connector because it's not plugged into anything. Once you jumper it, turn the key to the on position, but do not start the car. Just turn it to where all the dash lights come on. If you jumpered the connector properly, your Check Engine Light should start blinking. If you get no blinks at all, check the jumper and put the paper clip points on the other side of the metal tabs in the plug.
You need to count the short and or long blinks. For example, if your Idle Air Control Valve is acting up, you would read a code 14, which would be 1 long blink and 4 short blinks followed by long pause and then repeat. If it is a single digit code it will be short blinks only. Compare the code you get to the chart below. If the Oxygen Sensor has never been replaced in your car, I suspect the code you get is going to be related to it. The slightly hard starting and the stumbling are symptoms of it failing. If you smell any gas while the car is idling weirdly, that's another sign. A failing O2 sensor plays havoc with the air-fuel mix in the car and causes poor running.
You can also go to Autozone and ask them to read the codes. Don't be surprised if they ask you to use a paperclip, though. Good luck.
OBD1 Trouble Codes:
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system
Old Nov 12, 2010 | 05:58 AM
nus_dogg's Avatar
I'd check the FITV for your high idle.
bassrocker521
Feb 20, 2008 05:51 PM
importtuner07
Sep 3, 2006 04:44 PM
dan4h22a
Oct 27, 2004 10:41 AM
LostSoul
Oct 18, 2004 06:56 PM
dilow
Sep 1, 2001 09:31 AM
